Anyone have dyno / times at 10 PSI
lets see if this thread gets any replys, lol. im curious as to what people are putting down on the rollers / what the track times are around the 9-10 PSI level. my car will be tuned to 10 pounds this weekend and i cant really find anything in that ball park that is consistant. through a tight stalled 60e and a stock engine i'm looking for 475-500 RWHP and traps in the mid 120's.
The Trans is good its got about 3000 in parts and was properly built..i'm aware all cars differ but I probably won't track the car until the end of summer because its too far and expensive. Posted from LS1Tech.com App for Android
10lbs isn't 10lbs on two different turbos. I would hope my gt91 would make a little more power and go a littler faster on 10lbs than a t76 or similar, lol. You can't just use boost pressure. 500whp will probably run in the mid 11's maybe a touch quicker, also depends if the car has a good suspension under it and on what tire.
360cfm ported LS3 heads are going to work magic vs. 260cfm stock heads.
10psi means nothing without any more info on what you are running. Every turbo is rated at a specific lbs/min volume of flow.
My buddy made 950rwhp on 14psi with a forged LS3/ported LS3 heads/intake and single T4 turbo. On 10psi it probably made 850rwhp. It was a GTS76 with custom wheels on both sides.
Thats what i figured. My last ride @ full weight unlocked stall 410 RWHP trapped about 118 100 pounds heavier then this car so another 70-90 RWHP unlocked should get me in the 120's maybe even higher who knows my tuner is pretty confident in LS bottom ends lol.
