May run into some issues (Injectors & Map Sensor)
Old Jul 26, 2012 | 01:53 PM
Tirefire's Avatar
Default May run into some issues (Injectors & Map Sensor)
Hey guys needed to get some feedback on who has used 80 pound injectors with an F1A with a 3.90 pulley. My problem is that I started off my build (AES 390) with 80 lbs. injectors and my D-1 that was going to be maxed out with a 3.4 pulley and my two small 4.5 twin intercoolers. Anyways I upgraded to the F1A/front mount and now I'm stuck with 80 lbs injectors and a 2 bar map. My 2 bar sensor I here only goes up to 15 lbs. but I'm sure I will be making more than that with the 3.90 pulley. Can someone give me some adivise besides changing out the pulley. I hate spending twice but I fear I just might have to!!
P.s --I'm also running alky..
Old Jul 26, 2012 | 02:37 PM
9sectruck's Avatar
yeah you will make more then 15psi, my straight f1 on a 3.7 made 22psi at 6200 and didnt red line in tell 6600 but ran out of fuel.
I was running 80lbs injectors and twin intake pumps with a 2 bar sensor, I band-ad it in the tune as I would see 15psi around 4200 so I set the pe table to add the extra fuel from 4200 up, but ran out of pump about 6100, this is a band ad not the right way to fix it, the injectors by scale where 88% at the 6100
Old Jul 26, 2012 | 03:12 PM
Tirefire's Avatar
Originally Posted by 9sectruck
yeah you will make more then 15psi, my straight f1 on a 3.7 made 22psi at 6200 and didnt red line in tell 6600 but ran out of fuel. I was running 80lbs injectors and twin intake pumps with a 2 bar sensor, I band-ad it in the tune as I would see 15psi around 4200 so I set the pe table to add the extra fuel from 4200 up, but ran out of pump about 6100, this is a band ad not the right way to fix it, the injectors by scale where 88% at the 6100
Ok let me see if I get this, I can run the 80 lbs. injectors but the only thing that I would have to worry about would be my map sensor, correct? Since it only goes to 15 psi. This is only a base tune to break the engine in so when I get to the tuner, I'll just switch the 2 bar to a 2.5. What kind of psi will I see with a 3.90?
Old Jul 26, 2012 | 03:28 PM
9sectruck's Avatar
I would say around 17-20 at 6500ish, depending what heads you have cam, theirs alot that plays a factor on the boost that it will actually make.
if anything waste gate the cold side I did that for about a year to keep the boost downn to 13psi on my stock engine.
and on the injectors 80lbs will be pushing it if you ever turn it up to max the blower out.
Old Jul 26, 2012 | 03:35 PM
9sectruck's Avatar
on break in I would leave the blower belt off seat the rings the right way (NA) if you wash a cylinder down your going to kill the engine before you really get to play with it
Old Jul 26, 2012 | 03:54 PM
Tirefire's Avatar
Ok I heard it didn't matter but better save than sorry.
Old Jul 27, 2012 | 09:07 AM
MaxxMitchell's Avatar
Why not spend the money to go 3 bar, no more band aiding the tune? I've run the 2 bar before with over 20lbs and it does work but its also nice to be able to correctly read the boost in the logger and tune for it. It sounds like with that combo you are looking to make some pretty good power down the road.
Old Jul 27, 2012 | 10:56 AM
Tirefire's Avatar
I talked to my tuner yesterday he advised it would be wise to get a set of 96's and go with a 2.5 map. I told him about the 3 bar but he really did not feel it was necessary right now. I believe the 2.5 map goes up to 21 or 22 lbs. The other thing is how much more boost I'll be able to get with a 3.70 pulley I'm on a 3.9 pulley and I really dont know if the 3.70 will put me over the 74000 impeller rpm max the F1A has. So many variables...
Old Jul 27, 2012 | 11:07 AM
Why upgrade it 3 times total instead of just twice and do the 3 bar now? What diameter is your crank pulley? You can use that plus the internal gearing of the F1A to figure your RPM at max engine speed.
It is wise to do the 96's, but I'm sure you don't want to spend money again on upgrading the map if you end up running more boost. There really isn't a down side to running a 3 bar map besides the resolution in boost, and that resolution is not nearly as important there as it is out of boost.
Old Jul 27, 2012 | 12:02 PM
Tirefire's Avatar
I believe its the 7.25 from ATI. Also is there a 3 bar map sensor that connects to the factory location (back of intake)? I've been reading there's a zr1 map sensor but who's using it?
Old Jul 31, 2012 | 12:26 PM
DSteck's Avatar
Restricted User
There is no plug and play 3 bar MAP sensor besides the Duramaxx sensor, which performs pretty terribly in drivability areas. The LS9 sensor has an offset that is negative, which can't be entered into a F-body tune (minimum offset is zero). You can do the old style 3-bar by running a vacuum line to it and mounting it somewhere. 2.5 bar plug and play sensors are out there, which are good to 22psi. They are custom modified factory sensors.
Old Jul 31, 2012 | 02:27 PM
Tirefire's Avatar
Thank you!!
Old Jul 31, 2012 | 02:49 PM
9sectruck's Avatar
a 3.7 from a 3.9 will only net you 2-3psi
Old Aug 1, 2012 | 07:12 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Hi Andy, the crank pulley is a 7.65. With your 3.90 you'll be close to max impeller speed, depending on where you shift at, and rpm at the end of the track. Below are two videos of my Camaro when it had an F-1A with a 3.90 pulley on it. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Aug 1, 2012 | 07:48 AM
Tirefire's Avatar
Hi Bob,
Thanks for the info.. I forgot the formula to figure out how to get the impellar speed.. Do you still remember how much boost your car made with that pulley, what map sensor and what injectors you had on it.?
Old Aug 1, 2012 | 07:52 AM
9sectruck's Avatar
rpm x step ratio of blower x crank pulley divided by the blower pulley
Old Aug 1, 2012 | 07:55 AM
LS1Tech Sponsor
Hi Bob,
You're welcome. I was seeing 18 to 20 psi. I'm not sure what map sensor we were using, we had installed a BS3 and Brent was doing the tuning. We were using 96lb injectors. http://shop.brutespeed.com/Delphi-96...lphi-96-lb.htm Bob
__________________
Old Aug 1, 2012 | 08:04 AM
hardrock21's Avatar
What brand are your 80lb injectors? What's your base pressure. Seimens and Motron 80lb injectors are rated 80lb @ 3bar base pressure. LS1 base pressure is typically 58psi, so if you have it at 58psi, they are closer to 94ish lbs at that pressure. Food for thought. I just got my Motron 80's lined out..Took me forever to get the injector calibrations correct.
Old Aug 1, 2012 | 08:08 AM
Tirefire's Avatar
I believe they are Seimens/Motrons. LOL I think the last time I looked I read Seimens. I'll have to call Lonnie from Lonnies Performance to double check..
Old Aug 1, 2012 | 08:09 AM
hardrock21's Avatar
I'm sure they probably are, those are the most popular. What's your base fuel pressure?
