T4 vs. T6 Which is more beneficial
I ran a s472 with 1.10 83mm wheel and loved it...22psi was great spool really fast....yes even when it was a 6 speed. At lower boost levels 9-12psi it wasn't really all that good...18-22 was at its happy place. When I switched it to auto (4l80) it really woke up even at 12psi. With the auto at 22psi in 3rd gear 3.42 gear it would spool 2100rpm 1 psi and 22psi was about 4200. Just had a eBay manual boost controller, but once it got to about 10-12psi it really started to spool up hard. Hope this answers your question.
And also rolling brake spool to about 12-14 psi before it will burn the 315 nitto drags off at 65mph lol. When racing from a roll I could brake spool it in 2 second gear to any boost I could hook...about 8-10psi. And this was all done with the t56. The auto makes for much nicer and easier launches on the street and really picked up compared the t56 but both transmissions worked great with the 72
You have any videos?
No don't have any videos....I should have but never did...I have a gopro now so maybe some time ill get some vids up. I finally broke the 10 bolt it has 161k miles on it and 12k of it has been on turbo power so I think it did pretty good...it's not completely broke just makes a **** ton of noise lol
#34
Id put 100 dollar bill on the T6 1.10 spoolig slightly faster than the T4 1.25.
If its got the correct evo for the ci and turbine it will spool fine unless you completely screw the pooch on the tuneup.
You start jerking timing out at 1 psi... theres not a turbo in the world that wont be laggy.
#35
You were told wrong.
#38
Well I guess that settles it for me. Its good to hear because I was getting tired of searching and coming up with unfinished answers. People swear by the search button but damn I wasted 1hr reading through crap. Thanks again man
#39
I've never driven a Turbo car, I don't want to race from a dig since I have the 10bolt. I was thinking more along the lines of highway pulls. 40-140 MPH.
#40
Man I wish I had some videos of me roll racing. At 12psi on my setup you will beat 600's from 50mph up....on 22psi like 30mph and up. Brake spool it first and you will take off. I always had 315 nittos I would ran them at 15psi when doing roll racing.
Specs on my car
Stock k member
Stock shocks front and rear
Zr1's 11's in the back 315's
Stock 10 bolt
Founders performance control arm drop brackets and sub frame connectors
Spohn tq arm
Proline springs
Nothing special car has 161k
Specs on my car
Stock k member
Stock 10 bolt
Spohn tq arm
Proline springs
