Need some advice - 6.0 and twins..
Old Jul 31, 2012 | 01:55 PM
6.0knightmare's Avatar
Default Need some advice - 6.0 and twins..
Hey all - I've been trolling these forums for awhile and finally thinking of starting my build. It will be a stock LQ4 with twins. I have a friend that sold me two on3 performance 76mm's for dirt cheap...
The question is how will these do on a 6.0? they have a 65mm exhaust side so I figured spool time shouldn't be extremely awful due to the small exhaust turbine.. i'll be running a t56 with a 3.42 gear if that helps any
Old Jul 31, 2012 | 01:59 PM
DavidPHumes's Avatar
You will have more power than you know what to do with using that T56. IMO they're too big for a 6.0 but that's just my opinion. I think 6262 sized turbos would be a better fit, or even twin T70s. I mean it will work... and it will scream, but lag is going to be an issue.
Old Jul 31, 2012 | 02:34 PM
canada4g63's Avatar
Twin 76's have made over 800whp.
Old Jul 31, 2012 | 03:11 PM
c0ncEpT's Avatar
Twin 76's have made double that.
Old Jul 31, 2012 | 03:40 PM
9sectruck's Avatar
if your set on twins sell and make some money off your buddy and go down to 60isg mm turbos or go lil bigger on a single
Old Jul 31, 2012 | 03:53 PM
When would the 76's spool? this is going to be a high speed highway car. its an 07 vette that threw a rod so i went with an lq4. i would much rather do a big single but i don't know where to put it...
i was thinking fender mounting the twins
Old Aug 1, 2012 | 01:52 PM
TurboS10's Avatar
Twin 61's will make more power than a stock head will hold and aren't too expensive.
-they are good for 1300 to 1400 fwhp-
A 62-65mm turbine is what you'll want with a 61-67 compressor.
Old Aug 1, 2012 | 01:56 PM
00MaroonZ28's Avatar
This. No point running twins when a big single is all you need.
Old Aug 1, 2012 | 04:53 PM
I'd rather go single but I dont know of a way to keep A/C and heat in a c6 with a single. I guess ill sell off these and try to get some smaller twins... If anyone has a suggestion on how to fit a single let me know haha
Old Aug 1, 2012 | 05:14 PM
qqwqeqwrqwqtq's Avatar
Well, that's if you don't care about lag/response.
Old Aug 1, 2012 | 05:20 PM
Timmy2Stage's Avatar
Tenured Member
A 60-62mm compressor and a 65-67mm turbine would be perfect. All the boost will be in by 35-3800rpm.
Old Aug 1, 2012 | 05:26 PM
SVTconfused's Avatar
this...
Old Aug 1, 2012 | 09:19 PM
If he's looking to drag race then that's not a huge deal when you can spool it up on the line. I know a ton of guys that were running twins then went to a single and picked up huge ET by running just a single big turbo.
Old Aug 2, 2012 | 10:00 AM
It's fine at the dragstrip sure, I didn't realize the op was just building a race car that was not going to be driven on the street.
As for your second statement, if you are trying to imply that a single is more capable than twins you would be incorrect. Show me any single turbo and I'll show you twins that can match the power and have faster response.
Old Aug 2, 2012 | 11:59 AM
2000RATA's Avatar
This^^^. I never could get my head around why so many guys here are hung up on a single?
Old Aug 2, 2012 | 12:11 PM
Tenured Member
People are stuck on singles because they have no experience with twin's.
The fastest street car in the world is running a twin turbo setup.
Old Aug 2, 2012 | 01:04 PM
98blackbirdta's Avatar
I bet you will turn those 76s just fine. You have them already why not run them??
boostedsl2's Avatar
single is more efficient and doesn't usually cost as much. the more complexity to a system, the more that can go wrong. most guys don't really take that into account until something breaks.
Depending on your power level i would think one 76 would be fine. Seems like that turbine might be a little small though. twin 76's seem like they'd be pretty sluggish, although you do have smaller turbine wheels. think 35r's run a 64mm turbine, so it might not be too bad.
Not sure about fastest street cars running twins, but ok....
Old Aug 2, 2012 | 01:41 PM
831jd's Avatar
What about twin on3 70's would that be better. How much power u looking for?
Old Aug 2, 2012 | 05:09 PM
Tenured Member
Larry Larson. Twin Turbo BBC running twin 88mm precision turbos.
Car has gone 6.9's @ 209mph. Driven to the track and back.
