opinions on cam
Old Apr 4, 2004 | 09:34 PM
mike m's Avatar
Default opinions on cam
how does a 226-236 with a 565-570 lift on 115.5 sound for a boosted car?
Old Apr 5, 2004 | 12:26 AM
Time2Kill's Avatar
MASS seller approved
Sounds like a good cam to me although the split on the duration might be bigger than most would go. Seems like most people like 4 to 6 degree splits. The duration might be a bit big for a stock cubed car. If the car is bored/stroked then it should be a pretty good cam.
Lift numbers see right in line for a stock cubed car, might want to go a bit bigger if you have extra cubes though.
Old Apr 5, 2004 | 02:39 PM
mike m's Avatar
ok now im thinking a 224-230 on a 114
Old Apr 5, 2004 | 03:00 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I've talked extensive to Terry @ Cam Motion and Chris Mays at Comp cams about supercharger cams, and I always try to get them to generalize. Generally speaking, here is what was said...
>5-6 psi, single pattern or 4-6 degree traditional split, keep overlap down
>more psi, 4-6 degree for sure, keep overlap low
>big psi, 6-12 degree split, race car stuff, might run more overlap if the duration is getting big
Comp tended to favor big splits more so than Cam Motion.
Old Apr 5, 2004 | 04:58 PM
SSHOTROD's Avatar
222/230 .544/.544 114 smooth idle, good power but with only 7.5lbs of boost, email me for a graph.
