most compression with boost? (success stories?)
As superdave said the installed centerline and intake duration will play a big part in what you can and can't run timing and boost wise.
A friend who races in Outlaw275 has a 94mm G-trim that he pushes 38psi through a 10.5:1 compression SBC. He runs M5, and could of gone higher if he wanted.
I have an 11.3:1 416 cu in engine and trying to see if I ran pump 93 with meth injection on top of it will I be ok or will I have to go to something like 110 fuel or c16 with meth?
Depends on the dynamic, but it's going to take a big ol' cam to bring it down enough to be considered safe on pump gas.
For pump and meth I'd want it around 10.5:1 maximum if the dynamic is right.
Curious about a procharger p1sc tuner kit for say 6-8 lbs intercooled 2 or 3 core if I can fit it.
