thoughts on my cam.
Old Aug 7, 2012 | 07:40 PM
burbalanche's Avatar
Default thoughts on my cam.
wondering what thoughts are on this cam for my turbo setup. valve lift.527/.549 deg. duration 266/271 deg. duration @.50 206/214 112 lsa
Old Aug 7, 2012 | 10:16 PM
I8UR4RD's Avatar
def not a turbo cam. sell it. get a speedinc cam
Old Aug 8, 2012 | 06:19 AM
Any idea why they would have reccomended and made a custom cam like that knowing its for boost? Wats bad about it
Old Aug 8, 2012 | 01:35 PM
TurboS10's Avatar
Depends on what you want.
an LS6 or LS9 could make more peak power.
That cam will make better part throttle and off boost power with the lower duration and tigher lsa.
The two factors close the intake valve sooner and probably open the valve faster to make more cylinder pressure and increase low end power.
The little cams need more exhaust duration within reason to get any rpm out of it. Otherwise the exhaust backs up and makes power go flat.
The comp thumper line is an example of this method to get rpm w/o an early open intake (long duration) and increased reversion killing power.
The LS6 and LS9 are similar in this method also.
I think crane has that cam off the shelf or close.
Old Aug 8, 2012 | 04:54 PM
ok well my ? is and maybe problem place i delt with reccomended that and .650 valve springs? but wouldnt them big spring not let it open then or am i thinking wrong? the setup im doing is going in a project im working on and its somthing for street really maybe a lil offroad no drag.
Old Aug 8, 2012 | 06:49 PM
stock48's Avatar
9 Second Truck Club
First off what is the combination this is going in? That cam would work just fine in a 4.8L/70mm combo, but a little small for a 6.0L/80mm.
Old Aug 8, 2012 | 07:09 PM
its 6.0 317 heads with hardened pushrods, .650 spring, hv oil pump,66mm bullseye power billetwheel running on e85.
Old Aug 8, 2012 | 07:18 PM
Fbodyjunkie06's Avatar
Why are you putting a 66mm turbo on a 6.0?
You are going to choke it to death. It might make 500hp with that turbo and the back pressure will be rediculous.
You also can't just look at a cams specs and say it's not a turbo cam, valve events and combination determine that.
Old Aug 8, 2012 | 07:28 PM
turbos way to small obv?wonder why the guy from bullseye would have told me that turbo then for my setup?for my power range he said the turbo was good for 550-800 i think and setup?idk.. what would be good tubo for the cam and setup i have then? any help would be appreciated thanks
Old Aug 8, 2012 | 08:13 PM
my buddys runnin a 5.3/68mm t6 with basically similar everything else makin over 5 to his big tires in 5k lb truck?
Old Aug 9, 2012 | 01:55 AM
stock48's Avatar
9 Second Truck Club
5.3L is more efficient with that turbo than 6.0L's. If you want 5~600 hp that cam and turbo might work long as it's got a decent sized hot side. Times in sig with a 6.0L and 212@.050 cam, but running a larger GT76/94/.96. Spinning the turbo so hard it kills the thrust about every 10 passes at that power. Shift at 5900rpm and let it spin 6800 thru the traps.
Old Aug 9, 2012 | 06:24 AM
Im doing 2.5" hot side.so with that cam n turbo id ony be 5-6ish rwhp tops?
Old Aug 9, 2012 | 11:42 AM
flewbyyou04r1's Avatar
i built a simalar set up about 3 years ago but i had a 76mm turbo cam specs were 234/240 .589/.589 on a 115lsa obviously hydraulic roller car made 743rwhp@6700 and 691rwtq@3200
Old Aug 9, 2012 | 12:13 PM
RAACCR's Avatar
Before anyone jumps to conclusions, if its a billet 66 from Bullseye, it could have a 83, 87 or even 96mm turbine; plenty of flow for a 6L. And the compressor would easily achieve the OP's goals as well. As for the cam, perhaps a little mild, but would be good for a daily driver in a truck/SUV or heavy automobile.
Old Aug 9, 2012 | 04:54 PM
yes its billet 66 and im not sure on the turbine right now its t4..i know the cam isnt ideal but i was going for more daily driven and a lil offroad its in a truck to and am running a t56 fuel system is pretty stout as well so not to concerned there thanks
Old Aug 10, 2012 | 09:42 AM
RAACCR's Avatar
For a daily driver / off-road truck with a manual trans, a boatload of torque down low is exactly what you'd want. The "right" combo for a drag race application would be aimed significantly higher in the rpm range than what would work best for you. That cam will build tons of cylinder pressure (and thus torque) down low. With e-85 fuel to stifle the potential from knock that such cylinder pressures might cause, you've got an excellent combo IMO.
Old Aug 10, 2012 | 02:55 PM
Ok makes me feel a little better.i know its not the options but hey
Old Aug 10, 2012 | 03:51 PM
stevieturbo's Avatar
If you want to use it, just use it. Almost any cam will work very well in an LS.
