Overtorquing Head Studs?
Old Aug 8, 2012 | 03:04 PM
9sectruck's Avatar
^^^ 8740 are fine, just dont get stupid with timing thats generally what lift heads,
Old Aug 8, 2012 | 03:15 PM
68 SS's Avatar
Originally Posted by 9sectruck
anybody have a part number?price for the 1/2 head studs?
I got mine from AES when they machined my LSX block for the 1/2" studs. Don't quote me but I think the studs were around 550.00 for the set.
Old Aug 8, 2012 | 06:27 PM
Cronic_Moronic's Avatar
Originally Posted by Burken01
So if I was going to run 317 heads on a ls1 block and plan to run boost up to 17-18 psi, you think my 8740 arp head studs will suffice?
I don't want to lift heads..
Opinions?
Denmah was running around on 22lbs of boost with standard arp head bolts and not lifting heads. From what I'm reading turbo cars are all in the tune.
Old Aug 8, 2012 | 06:47 PM
alexcoreas's Avatar
And I thought these were expensive http://pages.ebay.com/link/?nav=item...d=380394108107
Will these be ok for 15lbs on a 02 4.8 bw s475?
Old Aug 8, 2012 | 06:49 PM
Old Geezer's Avatar
Thumbs up Yep...
Originally Posted by Reckless
We use 100 max on our 1/2-inch head studs. Anything beyond that and you risk crushing the aluminum on the heads. We usually end up around 90 on the 11mm ARP stuff.
Have seen it on turbo Buick aftermkt heads...The support columns that the studs are in collapse...
Old Aug 8, 2012 | 08:44 PM
I8UR4RD's Avatar
yeah thats the price.
Old Aug 9, 2012 | 09:04 AM
Reckless's Avatar
Super Moderator
There are better deals out there
Old Aug 9, 2012 | 09:50 AM
mike13's Avatar
I would talk with Kurt Urban performance they have experience with 1/2" head studs and also have them in their online store. I think I have mine torqued to 105ft lb's but I also have 3/4" thick decks
Old Aug 16, 2012 | 03:24 PM
JoshuaGrooms83's Avatar
whats the difference in proceedure for arp head studs verses bolts?
Old Aug 16, 2012 | 03:45 PM
ProTreeRacing's Avatar
1/2 is should go 120
stock studs 80 is it with arp lube..they will break on the block side of the threads if much more.
Old Aug 16, 2012 | 04:58 PM
so on the studs you still do the 3 pass thing right, but do 80ft lbs on the last pass?
