5k rpm wall t76 370ci
Hi
I tried a search on this but didn't get the info i needed.
The setup is
370ci lq9
L92 heads unmilled
Truck manifold on driver side and fabbed a custom manifold for pas side (to clear a/c)
Patriot springs
Ls1speed tu1 cam
Wiesco -11 pistons
Callies rods
Stock crank
Arb studs allover
Br7 ngk plugs gapped to .025
Manual boost control
Boost never steady ( about to change to eboost 2 and tial wg to steady boost) it jumps up and down 15-19psi
Keeps hitting a wall at 5000-5300 rpm,
Here's what i did to fix it:
Changed plugs (new br7s)
Changed coils to truck units
Changed cam sensor
Fixed one bad inj connector
Still hitting 5k wall and power drops off,
tuner never got codes
Any ideas? Seeing that RPMmotorsports got 800+whp on about the same set up, i would be happy with a clean graph to 700-750whp
The setup is
370ci lq9
L92 heads unmilled
Patriot springs
Ls1speed tu1 cam
Wiesco -11 pistons
Callies rods
Stock crank
Arb studs allover
Changed cam sensor
I'd be willing to bet the back pressure is insane on a 6.0 with a 68mm turbine turbo. Take that back it is insane on that turbo and is more than likely why you're hitting a wall.
The reason the boost is jumping around is because you're getting a false reading from backpressure making it's way back into the intake and causing the boost reading to vary and jump around.
I see it time and time again people choke these ls motors to death with turbo's that are too small.
9 Second Truck Club
I get that my turbo is small for my engine but it was what i had on the car back when it was a 5.7l , even at that time the dyno graph would fall off at about the same rpm.
I have a 6.0 with a 79mm turbine and its done around 5300ish rpm. I makes perfect sense its bp. You can check it by buying a $50 boost gauge on ebay that goes to like 60psi. Tap into your merge or any where before the turbo. And take a friend for a ride. Im at 2:1.
As for right now the PTE76 is the only thing available with the larger turbine wheel. The Tnetics units will not be out with the newer turbine wheels right now until Sept.
