78gts vs pt88 log comparisson
Old Aug 15, 2012 | 11:11 AM
HydroStream6's Avatar
I've been 146 on a 78GTS at over 4200lbs as well.
Old Aug 15, 2012 | 11:54 AM
rotary1307cc's Avatar
149 @ 12psi boost and 3050lbs
i am sure it would much faster if i pushed it on the turbo, but it was 100 out and i was not going to bump the boost when i couldnt hook anyway
the motor likes this one much better, very easy to feel
no back pressure data, but loosing boost is obviously coming from a bad intake to exhaust pressure bias
remember this is a 370" 10:1 engine with 360/250cfm heads and a 232/242-113 cam, u can tell the engine likes it above 6k but the turbo did not
and the the gts is a 75/82mm turbine, the pt88 is a 84/93mm turbine
Old Aug 15, 2012 | 12:38 PM
9sectruck's Avatar
(pt88 is a 84/93mm turbine) it is? I thought they where 83-84 on the hotside.
so your cam has around 11degs of over lap if I calc. right
damn near the same engine im trying to build 365 10.2 ported l92
your 9.20 is where my goals are.
Old Aug 15, 2012 | 06:27 PM
oh yeah it will rip no doubt about it, i still have a smile from last night on 15psi
the regular pt88 is a 11 blade turbine so you cant just slap a caliper on it and get the exact amount, but it is close to 84mm exducer and 93mm inducer
Old Sep 10, 2012 | 08:28 AM
i just wanted to share the pt88 did make a very nice difference at the track
it now backhalves correctly, you can just feel it is strong out the back and doesnt lay over
this was 14.5psi of boost since i am limited by the 2bar right now
next pass was a 8.91@158
before it would only pick up 28-29mph and def no where near that trap
yes my 60s suck
Old Sep 10, 2012 | 09:00 AM
SPRAYED 01's Avatar
What weight and car is this setup in?
Old Sep 10, 2012 | 09:19 AM
Ohh 3050-3100 depending on fuel
With me in the car, I am 165lbs
Note that I did gain 2 MPH in the 1/8 going from 19* to 22* timing. Br7 plugs e50
Old Sep 10, 2012 | 09:20 AM
It is an rx7
Old Sep 10, 2012 | 10:59 AM
SPRAYED 01's Avatar
Very nice, congrats on a killer car
Old Sep 10, 2012 | 11:20 AM
2000RATA's Avatar
Wow very nice gain! Congrats on a bad *** setup.
Old Sep 10, 2012 | 11:32 AM
gnx7's Avatar
158mph and high 8's....... gittin' it done
Old Sep 10, 2012 | 11:27 PM
  #32
skinnies's Avatar
congrats on the 8 sec pass
Old Sep 11, 2012 | 12:18 AM
  #33
2002camaroSS's Avatar
any videos?
Old Sep 11, 2012 | 08:30 AM
  #34
thanks guys, it was a great feeling, and a big surprise when i got back to the tower
i need to work with the suspension so i can get my 60ft in line now, then it would really go
it is funny because right now it comes out 20ft soft and then it moves out
i cant get it to take an initial hit of power without spinning, but once out a couple feet the little tires will hold all i can throw at it, i have full boost ramped in .5 seconds after i release the T brake
and here is one it was close to taking a hard initial hit but no go..... doe it seem like it is hitting the tires too hard or not hard enough on that hit? cant really tell if i need to drive the tires into the pavement harder initially or not so much
Old Sep 11, 2012 | 02:51 PM
  #35
Nitroused383's Avatar
Congrats on the 8 second pass. It looks like you need much more anti squat to be able to hit those drag radials hard. What size and tires are you running?
Old Sep 11, 2012 | 03:05 PM
  #36
SPRAYED 01's Avatar
Are those drag radials? What boost controller?
Old Sep 11, 2012 | 03:43 PM
  #37
Those are regular slicks. 26x9
And I agree after watching the vids about the anti squat. You can see watching frame by frame it doesn't drive the tire down on the hit and just trys to turn the tire. Thanks for the input on that
I am rather spoiled on the boost controller, I have an Ams 1000
That was the first I used it on the track I always was just a manual controller before.
That thing is so awesome, should of got one way sooner.
Once I get the chassis sorted out some it should be stout and consistent with the AMS
Works awesome on the street too, just save a different config for track and street, one second to change from one to the other
Old Sep 11, 2012 | 04:20 PM
  #38
Chicago TDP's Avatar
Sick ET...awesome job!
