Forced Induction Cam up for grabs!
Old Apr 5, 2004 | 01:02 PM
chrdij's Avatar
Default Forced Induction Cam up for grabs!
I have up for bid on ebay is a 230/224, 591-567 lift on an 112 Lsa. The cam is brand new and never used! The cam is a custom Grind for power adder set ups, and can be used with the stock converter on A4s. For more info please vist the link below or post it here, or just drop me a PM. Thanx Chris
http://cgi.ebay.com/ebaymotors/ws/e...item=2471793043
Old Apr 5, 2004 | 01:07 PM
MYTURBOT/A's Avatar
Thats not a FI cam i`ve ever heard recommended if it`s on a 112lsa. Maybe nitrous, but not a turbo or blower.
Old Apr 5, 2004 | 01:17 PM
chrdij's Avatar
This cam IS A TURBO/ Blower cam from Compcams, is not a F1,but is a Custom GRIND however. The cam was built for my turbo setup by Comp, but sold the kit, now need to sell the cam. If not sure please call Comp Cams at 1800 999-0853 to confirm that it is for turbo/ blower setup and give the specs and the custom grind #s that I have on the ebay link above
Thanx,
Chris
Old Apr 5, 2004 | 02:44 PM
grub-2001z28's Avatar
I agree, a 112lsa is not good for forced induction. you bleed off too much boost right out your exhaust valve...
Old Apr 5, 2004 | 04:27 PM
Crunch's Avatar
reverse split pattern not yet proven effective for blower cars. may be ok for turbo car. check with harlan.
Old Apr 5, 2004 | 04:56 PM
PongoX11's Avatar
Yeah I am ousting my current cam that is on a 112LSA for a Split cam on a 114 LSA for my upcoming D1SC
Old Apr 6, 2004 | 01:31 AM
y2khawk's Avatar
Old cam was 228/224 on 112, 112 ICL, slightly lower on the lift. It was VERY doggy on the bottom until the turbos came up on boost. Screamer then, but not the best cam IMO.
the new cam is MUCH better on bottom end response, but the rest of the setup is different. So who really knows if it was the cam or not.
FWIW, new cam is 251/248 .695/.687 115LSA 113ICL, solid roller. Still 348 cubes for both. This cam has about 15 degrees more overlap than the previous, 17 versus 2 believe it or not.
I had the old cam idle at 900 or so, this one idles at 1200 and sounds nasty as hell
The 112LSA cam was "ok", it made good power. But it was probably not optimum.
If i had the chance to do the hydraulic cam over, i'd go atleast 114LSA and a tad more lift.
just my .02
Old Apr 6, 2004 | 02:27 AM
HUGGER ORANGE SS's Avatar
Harlan. Thats one hell of a cam your running there. Any sound clips or videos?
Clint
