s10 rear mount turbo kit
Old Aug 17, 2012 | 10:19 PM
T76s10's Avatar
Default s10 rear mount turbo kit
hello, i was wondering if anyone would be interested in buying the whole entire rear mount turbo kit to my s10. im thinking on doing twins up front but i would need to sell this in order to do so. it would include headers, hotside pipe, wastegate, turbo + extra turbine housing, coldside pipe, intercooler, blow off valve, oil pump, oil lines, and all couplers. i would be willing to part it out, but if it were parted out, i would keep the blow off valve. here are some pics
cold side pipe
hot side pipe
oil pump location (old intercooler pipe)
oil drain return
http://youtu.be/plMHFwDg2wM
http://youtu.be/4naEUgfM7Vc
the oil feed is on top of the oil filter on the engine block. the oil return can be routed to the oil fill cover but you might need to buy more 1/2" fuel hose but thats no big deal. you would also need to cut the holes in the bed obviously and make mounts for the intercooler underneath. i will add in another v band for ease of installation and shipping. i will sell everything for $1700 shipped. i dont need to sell this set up but i think it would be cool to do twins. i would like to sell as a hole. i wont part it out until winter comes.
Old Aug 17, 2012 | 10:23 PM
Moter's Avatar
How much boost is this making?
Old Aug 17, 2012 | 10:39 PM
T76s10's Avatar
im only making 5lbs boost right now because i think the turbo is too big for my 5.3. im getting a bigger spring next week and ill see what happens. the spring i have in there now could be limiting it at 5lbs
Old Aug 19, 2012 | 07:13 PM
T76s10's Avatar
would really like to sell as a whole but if i get some descent offers on the piping ill part the rest
Old Aug 22, 2012 | 06:46 PM
T76s10's Avatar
I made 18lbs boost today. Makes boost super quick
Old Aug 22, 2012 | 06:47 PM
T76s10's Avatar
My intake was leaking so i couldn't make boost
Old Aug 22, 2012 | 06:57 PM
JAX04's Avatar
You probably oughta consider listing this in the classified section, this thread will probably get deleted/locked
Old Aug 22, 2012 | 08:02 PM
T76s10's Avatar
I do but i figured i would update it anyway for the who asked how much boost i was making
Old Aug 23, 2012 | 04:20 AM
95bowtie's Avatar
Is that an on3 turbo
Old Aug 23, 2012 | 01:26 PM
T76s10's Avatar
Yes. 76mn on3 turbo with .81ar, on3 44mm wastegate, turbonetics bov
Old Aug 29, 2012 | 02:36 PM
T76s10's Avatar
Its all getting parted out
Old Nov 5, 2012 | 09:52 AM
lsxtreme17268's Avatar
I know this is a bit of a old thread but is anything left from your Turbo kit?
