My somewhat coherent thread on the topic of street/strip turbo LS combinations.
Stroke and rod length has more to do with turbine size than actual cubic inches.
For comparison a 5.3 and a 5.7 should be looked at very similarly in turbine size for each because they both share the same stroke. Similar not identical though, I would say the 75mm turbine is as small as I would go on a 5.3 and a 75-83mm would be as small as I'd go on a 5.7 where as on a 6.0 I'd want no smaller than a 87mm-92mm turbine.
I bought a used TC78 with 1.15 A/R turbine and ballbearing center section to run on an L33 alum 5.3 with ported 5.3 heads, LS6 intake, 225/223 cam, and Chiseled A/W intercooler with a 6speed in a '69 Chevelle. Putting a 9" out back and 3.25 gears.
Hoping for 800rwhp on e85. My buddy made 830rwhp with this exact turbo on a built LS3 with ported heads/LS3 intake and 6spd.
#35
I agree with los, it's small even for a street car.
#37
I am so mad you posted this.....NOW I HAVE TO BUILD A TWIN SETUP THIS WINTER!!!! LOL
Great info....I can crunch numbers and try to build a "theoretical turbo setup" but you have the true data and knowledge to know what works and what fails.
Thanks Jim
Thanks Jim
#40
Great read, this validates a lot of my assumptions. Seems like most turbos are oversized by manufactures also. Garrett states the 3076 is sized for up to 2 litres making twins too small for 390 cubes, but looking at the compressor maps I came to your same conclusion. Being no expert, I was doubtful as this info is hard to come by.
