My somewhat coherent thread on the topic of street/strip turbo LS combinations.
#61
I have a PT76GTS (.96) on my 370ci, TU1 cam..
What cubes is too big for a 76GTS? It spools instantly and w/ slicks and off a transbrake I dont see why it wouldnt break into the 8's. I think it works great for a low-mid 9sec street car. I think a bigger turbo would suck...unless you wanted to go faster.
What would be a better turbo for me that I could use for my application and not have to worry about changing the hotside too much?
#62
compressor:
66mm inducer
91.4mm exducer
turbine:
80mm inducer
73mm exducer
BUT the very popular S480 is rated a 80/96 and has the wheel size spec configuration you mentioned. Was just trying to say that not all of their turbos are configured that way. I totally agree that some research needs to be done to make sure you are looking at comparable units.
#63
7675 on an LS is pretty much ideal on 5.3-5.7 IMO. 6.0 is the most displacement I would like to see it on.
I've tuned a few on 402-408ci and they max out at around 775rwhp with severe power drop off after 5500rpm (whereas they will do a bit over 900 and 6500rpm on a 346).
#65
#66
If my current turbo doesn't work out, I think a 7675 would be more than I will ever need.
Thanks for taking the time to share all this information. It has been great.
#67
Good info in here. Hopefully next week I can give some insight on how my ls3 headed 370 with a 76gts turbo works out with a t56. I am going for a killer street car that sees occasional track duty.
#68
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Any thoughts on E-85 or E-98 use for a street/strip car?
#69
I have a GT 42-94R on my Z06 cammed lq4. Blow thru car. Trapped 131mph on 12#.
It has a t6 housing on it which I'm not too fond of, but it still spools very fast once there is sufficient heat in the pipes and housing. I am very happy with this turbo for my combination.
Oh, that's also with 4" charge pipes after the giant 5.5" core intercooler. I'm sure that isn't helping spool time any.
#70
Restricted User
The 7675ceas are what we must be running on Steve's car but with 80 A/R housings. That's a 422 and twins spool very very quickly. IMO, a single one of those is undersized for any v8 (even a 4.8). I'm not saying it wont work, I'm just saying that something with a bigger exhaust wheel would work better.
#71
Well again, it depends on your goals. To say it's designed to be run as a twin or on a 4 banger is not correct when one of them will make 900rwhp and turn 6500+rpm on a 346.
I think we have a different definition of spooling "very very quickly". You're talking about a pair of turbos that can make over 2000hp so it's not going to be super responsive down low.
I did mention that with more displacement than a 6.0 I agree that I would not run this as a single turbo.
#72
Coal Mining Director
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
#73
I had a 76GTS on a 346 with a reverse grind 227/224 114lsa camshaft.
While I think this turbo is a little too small and agree with los, that with a reverse grind cam with less exhaust bias and a late EVO event it can work.
That said I am still a huge believer in big turbine wheels, tight ar housings and the correct camshaft to spool it with and run hard up top like a turbo should.
#75
I don't think reverse split cams are ever necessary. Every one I've tried has lost power and response so I stopped using them. Of course a 3 deg split isn't too far off from a single pattern cam anyway.
And don't get me wrong, if you couldn't tell by most of my posts I'm a believer in freeing up the exhaust side as well but the fact remains that a 7675 will make good power if you don't try and put it on too large of an engine.
#76
What power did it make?
I also don't like reverse grind splits and I go back and forth with a good friend of mine(you know who you are
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
I guess sometimes space is so limited or you have a guy that just has to run a turbo that is on the small side and in that case a small reverse split can work, but nothing I ever spec intentionally are reverse split.
Video of said car on 11psi:http://youtu.be/yS-3C-fC2iw
Dyno:
![](http://i1105.photobucket.com/albums/h344/fbodyjunkie06/th_rice_etr_dyno.jpg)
#77
I'm a firm believer in my reverse split cam. Sold it at one point. Installed a smaller, 228ish even pattern cam. Car was noticeably slower, and spooled slower too. After a year or two with it in the car.... I tracked down the reverse split cam I sold and the owner still had it sitting in the box I shipped it in
Bought it back, reinstalled it, and the car then hauled *** on the top end again.
A couple local tuners thought I was an idiot for thinking going to a smaller cam would be faster.... And they laughed when I reinstalled the reverse big stick and picked up hp. "Duh" they said.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#80
on my 6.0l cam only lq9 i had a tc78 at 12 psi would run 142mph swapped to the 7675 with no other changes car went 152 and ran that number consistently. the lq9 ate a piston swapped in a 5.3l with the same cam and with the 7675 best the car ran was 142.
