Best intake for motor?
Old Aug 18, 2012 | 06:31 PM
96s-10ss's Avatar
Default Best intake for motor?
I am building a forged 3.905 ls1. I will be running a 76mm turbo. I want to see 850 to the wheels. So my question is what intake will get me there? I was thinking the edelbrock vic jr with an elbow and a 90mm tb, or the 85mm typhoon style with matching tb. Any better suggestions?
Old Aug 18, 2012 | 07:44 PM
dudeman's Avatar
what style heads? cathedral port? if so, i would suggest edelbrock pro-flo xt if you have hood clearance.
Old Aug 19, 2012 | 04:47 AM
stevieturbo's Avatar
Stock LS6 intake and TB will get you there with ease.
Old Aug 19, 2012 | 07:54 AM
96s-10ss's Avatar
Yes cathedral port. from what I understood, the ls6 and 78mm stock t.b. Were maxed out at 750 hp?
Old Aug 19, 2012 | 08:09 AM
Cam72aro's Avatar
Mighty mouses old car had that setup. Not sure on numbers, but it ran in the 8's.
Old Aug 19, 2012 | 08:46 AM
96s-10ss's Avatar
Thats good enough haha
Old Aug 19, 2012 | 09:02 AM
As does Arun's Corvette....and it's in the 8's at 160mph
Old Aug 19, 2012 | 09:21 AM
Boo"SS"t's Avatar
I made 889rwhp on my old set-up with my factory stock Ls6 intake and throttle body, and others have made much more judging by the way their car's mph in a 1/4 mile.
Old Aug 19, 2012 | 09:32 AM
96s-10ss's Avatar
Sounds good. Thank you for the answer
Old Aug 19, 2012 | 03:31 PM
98Z28CobraKiller's Avatar
Restricted User
Yeah, no prob meeting your goals with LS6 intake and stock ported TB.
Just FYI, MightyMouse ran a ported and moddified LS6 intake that was reflanged to accept a 90mm TB. I actually wasn't aware that he had changed it,
Old Aug 19, 2012 | 03:34 PM
Storm Trooper's Avatar
You will see better results with a FAST intake IMO....
Old Aug 19, 2012 | 03:44 PM
95maroz28's Avatar
any have dyno results going from one to another? ls1-ls6-fast-victor
Old Aug 19, 2012 | 03:45 PM
Little proof to back it up though
Old Aug 19, 2012 | 05:28 PM
Sales@Tick's Avatar
What RPM do you want to spin this thing to and do you already have a cam chosen?
That will play more of a part of what manifold you use versus how much power.
A LS2 or LS6 intake will rev to 6800-7000rpm in a turbo application and make enough power to lift the heads off a 4 bolt block.
Old Aug 19, 2012 | 05:31 PM
I8UR4RD's Avatar
If you have the room go with the holley cathedral port or vic jr.
fast 102
and ls6 are good choices too.
Old Aug 19, 2012 | 07:48 PM
brians91formula's Avatar
What causes the heads to lift? High RPM, high boost, or just big horsepower in general? I'd imagine cylinder pressure is the biggest factor?
Old Aug 20, 2012 | 03:48 AM
On the most part I'd say it is people running too close to detonation. Power will play a part, but it will take a lot
Old Aug 20, 2012 | 07:54 AM
Sales@Tick's Avatar
Cylinder pressure.
Excess timing creates excess cylinder pressure, excess boost creates excess cylinder pressure, too small of a cam creates more dynamic compression which creates too much cylinder pressure, too much static compression creates excess cylinder pressure........etc. etc. etc.
There are a bunch of contributing factors.
Old Aug 20, 2012 | 10:54 AM
96s-10ss's Avatar
I will be spinning it ti 6700. Using an ls9 cam.
Old Aug 20, 2012 | 11:10 AM
FlashWS6's Avatar
Destroyer of Exotics
uhh? what?
