waterpump tapped for steam port?
Old Aug 27, 2012 | 06:50 PM
bad6as's Avatar
Interesting
Old Aug 27, 2012 | 06:57 PM
My6speedZ's Avatar
Originally Posted by Bobsmyuncle
i dont understand why ppl go thru all that trouble of making lines when u can just put a ls1 style setup on it.
I don't think you can get the part from GM anymore.
Originally Posted by j88l98irocz
Ls6 the ls1 has no block offs
This is true but you can notch the intake and use two LS6 crossovers and run a line with nice clamps.
Old Aug 27, 2012 | 09:48 PM
ren987's Avatar
Even if you did use the oem steam vents that connect all the ports, there is still a good chance they will be blocked. I cut one open and found some of the tubes to be blocked.I made my own set up and tapped the top part of the water pump.
Old Aug 27, 2012 | 10:10 PM
My6speedZ's Avatar
Well yeah I was just saying if you do tap into them you can use them.
Only the the ls1 heads from pre 01 will be tapped right? 799 heads from the gto didn't use rear steam ports or the 243 heads because all of those used the ls6 intake.
Old Aug 28, 2012 | 12:11 AM
02anti_vnm's Avatar
I'm using a truck style vent system I blew air through every port and they were clear. No hassle with making some big over engineered setup. Clean simple and just as effective.
Old Aug 28, 2012 | 01:54 AM
runninfromthelaw's Avatar
So there a way to use a vent release like what is used on the lt1 and tap the water pump to help with trapped air?
