procharger question???
I have asked procharger on how much boost it would make they said about 3 to 5 lbs. The car made about 2.5 to 3 lbs.
My question is basically asking, is this on par on what the car should be making for boost? Or do I have slippage or leakage issues that I need to check out. Procharger is the only one to give me a strait answer.
Check for belt slip first. I have madr 9psi with my p1sc1 already. Different pulley combo tho. A boost leak is also possible
Check for leaks too
Any dyno numbers?I have asked procharger on how much boost it would make they said about 3 to 5 lbs. The car made about 2.5 to 3 lbs.
I am using the vacuum port off the throttle body that goes to the passenger side valve cover
Now I have 2 choices to upgrade. I can upgrade to 3.1 or 3.0 for the 6-rib. I would like to get an ultra grip pulley but there website is broken. What pulley do you guys recommend to use for 5 to 8 lbs @ 5.5k to 6k rpm with minimal belt slip issues. I just have a feeling that's going to be my next issue. I also have 2 Weeks to deliver the car to my dad finished.
With a good tuner and setup person you should easily make 500 rwhp at 6-7 lbs of boost. A good shop could easily do what you need in 2-3 days since you will be bringing the parts to install with you.
A trip to D & G Dyno Tune in Hennesssey OK finds you a shop who is an ATI distributor who has a Mustang dyno, and uses EFI live to tune. He has a very good reputation in that area as well as Tulsa, Oklahoma City, and Wichita.
He has tuned mine twice because I went to a smaller pulley. I have a 98, so the tune is a little harder and more time consuming because of way the tables are modified in a 98. Since you have a 2002, a custom tune is ideal with your PCM. I have an SD tune, you can get a MAF tune as well.
I have PM'd you his number. He prefers to tune on GM cars, but has a bunch of customers with Mustangs as well.
If you don't already have 42 lbs injectors, those will have to be installed as well as an upgraded fuel pump. A Racetronix fuel pump and hot wire kit is the best and cheapest solution with capacity to spare later to take you to 600 rwhp.
Here is a pic of my car while I had it at his shop being tuned on his Mustang Dyno.
http://www.flickr.com/photos/1835930...57623345499537
http://www.flickr.com/photos/1835930...7623345499537/
DeWayne knows how to tune and he won't screw you around. I have spent nearly $3000 with a nationaly known tuner in Indiana as well as three in the Kansas City area - I lived there for 10 years. My car now has the best tune ever after D & G in Hennessey tuned it.
If you are the type who wants to know what he is doing while he tunes your car - he will take the time to explain what he does each time he runs it on the dyno as he tunes each rpm level.
Give him a call - I am sure he can get everything done within two weeks.
I drop ship the above kit directly from ProCharger, provided they have it ready to go it could ship out today to you. As has been mentioned, the larger 8 rib's 7.65 crank will really help out your system. Bob
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
You can order the parts thru Bob at Brute but ATI will let you pickup what you order thru Brute directly at ATI in Lenexa as I did to save time and shipping costs. Bob sells injectors as well.
But now we are fighting a lean hump as it is coming into.boost. Fuel pressure is dropping in relation to boost. But the air fuels are fine up top. Is it a fuel pump issue or with the stock fuel pressure regulator as the pressure in the cylinder is building on the injector side its derating the fuel pressure rating. At 0 in of vacuum the regulator is at 58psi of fuel pressure and at 5 psi of boost the fuel pressure is at 53 psi
The Racetronix Kit has enough pump to take you to 600 rhwp (power adder rwhp). My 98 Racetronix kit maintains a constant 57-58 lbs all through the rpm range while on the dyno (Mustang).
Not related but:
I have a D1. We ran out of injector with 42 lb'rs. I had to replace with 60's.
Also you have made no mention of the size air filter you are using. Bob at Brute has mentioned time and time again the benefits of substituting the ATI supplied filter with a bigger K & N air filter.
Fuel pressure immediately drops at WOT, but it drops to 54 PSI but it just stays there. The airfuels are good at WOT so I am not worried about it.
