Huron Speed On3 T76 Dyno Results
Eboost street is like 275 and has almost all the same features as the eboost 2 except boost by gear. I also ran a turboxs manual controller and was losing 4lbs on the top end. Just by swapping to the eboost street i gained 100Rwhp from 5k-6500. I didnt even have to use the RPM boost compensating feature on the controller.
$275 for an eboost is not bad. Thats probably the route I'm going to go.
I was going to sell the 76mm and get a S475 but after seeing some decent power I'm going to hang onto it for a bit.
My boost comes on alot better now that the exhaust leak is fixed. I'll try and post up some in car pulls.
I'm still going to remove all the hot pipes and wrap everything with header wrap. This should help with spooling too.
My project this weekend is building a full exhuast. Quite like a stock ls1 and fast like racecar
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
