Anyone running a ls9 in a 4.8
Old Aug 27, 2012 | 09:20 PM
denmah's Avatar
Moderator
me and some friends made 500whp on a totally stock 4.8, stock valvesprings, cam, you name it, 16psi with a borg warner s475.
the valvesprings were hating life, but it did it.
thru a th350 trans and 8.5 rear.
Old Aug 27, 2012 | 09:22 PM
denmah's Avatar
Moderator
Originally Posted by anheuserbusch08
run the stock ls6 cam add boost and ull see 600+. ull probably throw a rod or 2 but hell theyre cheap at the junkyard lol
i made 675whp through a th400 on a 2001 4.8l
Old Aug 27, 2012 | 10:11 PM
gone_in_10sec's Avatar
What injectors and fuel pump were you using?
Old Aug 27, 2012 | 11:58 PM
denmah's Avatar
Moderator
single bosche 044 pump and 80lb injectors, only using half the injectors
Old Aug 28, 2012 | 07:54 AM
Stangkilr's Avatar
My car runs its *** off with an LS9 cam.
Old Aug 28, 2012 | 08:57 AM
denmah's Avatar
Moderator
it drives and idles so ****** nice with that ls9 cam too, my friend drove my car to the track and raced it, i nearly fell asleep in the car. great mileage too if you have a street car.
Old Aug 28, 2012 | 09:29 AM
NemeSS's Avatar
I actually prefer the stock truck cams. Since they idle nice, and are pretty responsive and they do well with psi for a street car. I would rather get some dual springs and pr. Than a cam. If its just a stock 4.8/5.3. The boost will make up its own power anyway.
Old Aug 28, 2012 | 09:45 PM
I know I'm from kc as well, when ever I figure out witch cam gear I need, I'll be hitting up Justine for a tune
Old Aug 29, 2012 | 07:33 AM
Stangkilr's Avatar
He does a good job!
Old Aug 29, 2012 | 08:10 AM
denmah's Avatar
Moderator
if you have a 24 tooth crank you need a 1x front cam gear
if you have a 58 tooth crank you need a 4x cam gear...
i have a 4x cam gear i bought as a mistake if you want it i will make you a hell of a deal and ship it to you just so i can get rid of it lol
Old Aug 29, 2012 | 07:38 PM
I'll have to check when I get back to Missouri next weekend
