Hi Comp Twin Turbo Build
370ci 6.0 LS with twin PT6766s CEA Turbos 11:1 compression No intercooler With Dual Fuel using 16 Injectors (Pump gas + Methanol) Controlled by Holley Dominator EFI.
The Idea is to have very Efficient Motor off boost with the small primaries and very powerful Motor taking advantage of the Methanol on the secondary injectors without the need for the intercooler even with the hi comp that will help spooling the turbos at low RPM.
I'm thinking of ramping the methanol injectors on when gas injector reach 80%DC and will try to size them to reach there at about 105 KPa. this way i should have the least amount of gas with boost just to be safe and i should be able to run a lot of boost with a lot of timing.
the reason i thought about that is i already have most of the stuff to make it happen.
11:1 370ci 6.0L LS short block with callies Rods and wiseco Pistons.
225 ETP Heads.
Moran 235 LB/HR Injectors.
built 4l80e Trans.
And access to cheap Methanol.
My goals are 1000rwhp street/strip beast.
What do you think guys?
What should I pay attention to?
we should compare notes man.
I like you setup, would you tell me more about it? how much power your making? any head lifting?
