F1A or F1C ?
Old Aug 27, 2012 | 02:12 PM
skinumback's Avatar
Default F1A or F1C ?
I would like to get some ideas on if I should
get a F1A or F1C for my build! Please respond
With details of which one and why, thanks!
This is my combo iron 6.0, 317's with stock valve
Size, 242/242 112 cam motion, stock rockers with
upgraded trunion, duel springs, 9:1 comp, gmpp
88958675 manifold, pro systems blow through
carb 3.622 crank in a 1993 c1500 silverado,
4:10 gear 275/60 et streets th400 3500 10" converter!
Street driven on weekends! Thanks for the info,
And please reply only if you have or have had
Experience with these blowers and similar
Combination!
Old Aug 27, 2012 | 02:33 PM
+badss+'s Avatar
Might wanna look into a different cam for either but what are power goals?
Old Aug 27, 2012 | 03:02 PM
skinumback's Avatar
What ever it will make on 10-12# 650
rwhp or so! I would like some room to grow as
well tho not as much for power but I would
Like to one day build a 4xx CID for it! When
You question the cam is it because of the
112 lsa? Just curious
Old Aug 27, 2012 | 07:39 PM
I8UR4RD's Avatar
if thats all you want save the money and go d1.
Old Aug 27, 2012 | 10:01 PM
6D9 Matt's Avatar
Agreed... you dont need an F1 to get what you are looking for.
Old Aug 27, 2012 | 10:25 PM
+badss+'s Avatar
your gunna want a lil more split on exhaust side and like a 114-115 and id still say do a f1 so when you do go 4xx itll already be there do it once and be done you can just swap pulleys from there.
Old Aug 28, 2012 | 06:40 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Question
Combination!
Are you using the ProCharger truck system that uses the same belt for the ProCharger as the accessories? Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Aug 28, 2012 | 09:18 AM
skinumback's Avatar
Smile
No, I was planning on going with the universal
LSX kit with a cog drive!
Old Aug 28, 2012 | 09:42 AM
LS1Tech Sponsor
Cool, the F-1A would be what I would go with. Your stock head deck thickness would be your limiting factor to max out the F-1A, you'll want to keep it under 16 psi, but you shouldn't have to run more than 12 psi to meet your current goals. Bob
__________________
Old Aug 28, 2012 | 10:42 AM
josepy121380's Avatar
F1a. I wish i would have a F1a instead of the f1c. The c is a big bitch and a snug fit.
