Procharged 347 question
Old Sep 5, 2012 | 11:13 PM
5w20's Avatar
This thread went way off topic.
Old Sep 6, 2012 | 11:16 AM
fatmat80's Avatar
Originally Posted by CyaPussy
A well built 347 head cam etc with d1 15 lbs of boost should make what around 650 rw or is that a low ball number also am not looking to use methonal.
I think you are right in line with the avg for this setup..Most people have made between 625 and 700 on avg with the 347/d1sc combo..But like mentioned before, good flowing exhaust and heads will lower your boost at a given pulley combo, but will net you higher rwhp. Goodluck with your combo!!
Also prior to reading your thread there is another one by eboz06 that details a similar combo making 800+rwhp..
Old Jun 18, 2013 | 08:10 AM
handyandy496's Avatar
Too much hot air in this room...lol
Old Jun 18, 2013 | 08:21 AM
Is there a thread in here on adding some pure oxygen (small amounts) into the intakes to compensate for spark blowout in e-85 fed low static compression engines instead of mixing with pump gas.
