f1A back feeding help!!
Old Sep 3, 2012 | 12:34 AM
baycityrides's Avatar
Default f1A back feeding help!!
i know its on my LT1 but its all the same principle. my intercooler was plugged so i put a brand new one in, so there should be no restrictions. as im cruising i can hear my bleed off pressure back feeding through the blower. its also only building 5 psi of the 18 it should be, i checked my ATI race bypass and its functioning properly i.e. the diaphram is not torn, im frustrated as i cant figure out whats going on... has anyonne encountered this before? i called procharger and they where like talking to a brick wall...
Old Sep 3, 2012 | 02:18 AM
js2fst's Avatar
Where is your vacuum source try putting a manifold in brake booster line
Old Sep 3, 2012 | 12:16 PM
fixed it... there was a hair line crack in the vacuum line... stupid i know but it was under my breather so i didnt see it when i inspected it. i said F it and replaced all of it and found it when i pulled the line out.
