how many 5.3 turbo guys with 706 heads?
They are different. The 5.3 (706) head has a smaller combustion chamber and smaller different shaped intake runner than a 862 head. The 862 is the same as a 241 and 806 ('98) heads. Except for the notch on the deck surface. A ported 706 head would be the ticket on a boosted budget 5.3. The reason is the intake runner is still smaller ported than a 799/243 head unported and will out flow either of them by 40+ cfm. So what you have is the compression you want, a head with great velocity and flow for off boost and transient response. Simply put ported 5.3 heads would murder a set of unported 799/243's out of boost or in.
