80lb injectors for 6-700whp(e85?)
i didn't ask about the timing- he did comment it was safe.
but adding more timing may have yielded more HP but more HP requires more fuel right -and if im already at 90% DC
the car did spin on the dyno so not sure if that cost much HP.
Jacking the fuel pressure up to 60 will affect the tune and require a retune.
ive followed your builds and like them a lot- I regret going with HP tuners and wish i would have gone MS now but I already bought the harness, pcm etc for my swap.
What pumps and fuel pressure did you make the 697 at ?
im *** deep into HP credits and dyno time but may make the switch to the the MS3 later.
I saw you post that they were working on a direct fit lsx application.
From what I’ve read you need 35psi minimum to get a decent spray pattern on the injectors. The more pressure the better the pattern/atomization of the fuel.
Honestly with the new badass 450lph e85 walbros I don’t see why people are still using the 255lph pumps.
Going by my experience with 120lbers I don't think 160's would idle well, even with E85. My idle is bearable, but I can’t get the pulse width high enough to get a great idle. Going by my DC numbers 120’s should support 1000+ on E85 at reasonable pressures.
I run:
40psi base pressure. (20lbs of boost)
magnafuel 750protuner pump (loud bastard!)
1/2 feed lines and OEM fuel rail
120lb injectors (low-z with AEM driver box)
E85
Logs showing 55% DC at right around 700whp (going by weight/trap speed)
