80lb injectors for 6-700whp(e85?)
#41
1 Post
Good info for sure! Im going to run twin walbro 255's through the stock lines with a 1/1 regulator returning through the evap line 80# deka injectors on e85. Bought a Huron speed kit with magnum 80mm turbo From slowlsx on here just waiting for it to arrive. Should be plenty for a stock ls1
#42
1 Post
So Ive been talking with my tuner and He seems to think I will run out of fuel "e85" before 600rwhp on their dynamics dyno. What do you guys think? Again Fuel system is stock rails, lines, 1/1 malory fpr, 80lb deka injectors. Dual Walbro 255's hot wired. And I'm @ 6000 ft elevation.
#44
Injectors will support 900+
Stock rails will support 900+
Fuel pumps will support right at 800rwhp when they run out, I never recommend more than 750rwhp with 2 walbros. You can add a boost a pump and support 850+ rwhp
Run 65 base fuel pressure
This is all off proven real world situations I have done on several cars.
I've never actually measured exactly, but I believe they are 3/8.
The following users liked this post:
CARFREAKS (08-24-2020)
#45
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
#49
I use E85. On my C6 I'm using a stock LS3 in tank pump, a Bosch 044 external running off my drivers side tank, and a return going back to the drivers side tank. Stock LS3 fuel rails. Pressure set at 58psi and it's not boost referenced. 673rwhp and my FIC 103#(at 58psi) injectors are at 91% duty cycle. Dyno was done in 116F Phoenix heat and correction factor was 1.07. If I was boost referenced I would gain a little headroom, but not too much as I'm only at 12psi. I'm going to add meth to know down my IAT's and that will take a little load off the injectors. Currently I'm at 11.2:1 AFR on the gas scale.
#50
Skinnies- I'll be running 95% street. Are the cars your talking about full time race? Street? I was wondering if you have any problems, running high pressure on the street, as far as heating the fuel?
#53
In case anyone wanted to know what 80's will do on a 3 bar base fuel pressure -- I switched to E85 a few days ago and am running at 43.5 base psi. It's a boost referenced regulator, and at 12psi I was at 98 IDC. I'm also spraying pure meth through dual 10 nozzles. I would guess I'm in the 650rwhp range through a 4l80e.
