TUNERS: discussion of ignition timing and spool time
That way he has full normal timing when driving around and cruising so when he rolls into it he is using the same method as we are.
this applies to your entire PE scenario as well as on the transbrake. For a M6 car either do that or anti lag it with 5* timing and 11.5 AFR
Heres a discussion from 07 we had in here
https://ls1tech.com/forums/forced-in...me-tuning.html
I use a very similar strategy to what Grr mentioned. 35-38* to reach the 2 step RPM. Then drop it to like 25* on the 2 step and then it pulls out another 5-7* by 5.5K RPM and flat to peak around 18*.
Same goes for the fuel. Start lean and once on the 2 step richen way up to target (11.5 AFR).
Moe, you mention PE TPS % and how its an issue but it shouldn't be. When you launch the car, you should be in PE mode because you should be at 100% TPS. Same is true for when you get up on the 2 step. So not really sure I'm understanding that part of your concern.
Also there is a hysteris for PE to keep it from coming on until whatever throttle percentage you have it set at.
I like to use open loop fueling for everything up to atmospheric pressure then let PE take over and use BE for over boost situations only.
So that way my open loop fueling tables control everything until basically I see boost then PE takes over. This way I can keep the open loop fuel adder table lean to help get up on the converter, then slowly start to taper fuel in as kpa rises to over 95kpa with PE and keep slowly adding fuel until I'm around 4psi then put the commanded fuel coefficients in that I would run down track and above 4psi to achieve my desired commanded AFR.
I also use AFR spark correction to add timing to my main table while I command my desired fuel coefficient I see on the foot brake while spooling(usually 13.5:1-12.8:1 and I'll add between 8*-14* to a base of 26*-28*) and then as I see boost rise I slowly take that added timing away until I hit 3-4psi and take the spark correction back to 0* and allow the timing coefficients that are in the main table that are used in full boost past 4psi(usually around 16-18*) to be the only units actively in use. Once I hit 3-4psi on the foot brake I let PE go to 12.0:1 at 4psi and then ramp more fuel to 11.6-11.5 at full launch boost and all the way down track as like Los said it really allows the fuel to light off as you have moved the combustion into the headers closer to the turbine.
I've found this method to give me and others I have helped the best spool time they have ever had as it allows you to be lean and mean on the foot brake, add in extra timing without messing with the main timing table that you use for down track boost, allows you to pull that added timing back out and add the fuel you need in progressively for boost and not flood the motor out with fuel when you're trying to build boost to get up on the converter/2-step.
