ls1turbo help pleasee
Old Sep 12, 2012 | 06:45 PM
brentu2007's Avatar
Default ls1turbo help pleasee
Ive got a 98 camaro ls1. Motor has 180,000 miles on it stock motor. is it a bad idea to build this motor and put a turbo on it?
Old Sep 12, 2012 | 07:12 PM
denmah's Avatar
Moderator
it certainly wouldn't stop me.
Old Sep 12, 2012 | 07:18 PM
98 ls1 jimbo's Avatar
i say go for it. Have fun.
Old Sep 12, 2012 | 08:21 PM
a-low's Avatar
Go for it. Check your plugs for oil/compression test and let me know how it goes since mine
has 160,000 and im thinking about just using it oposed to getting a 5.3
Old Sep 12, 2012 | 08:37 PM
denmah's Avatar
Moderator
honestly if i were you guys with ls1s i would pull that **** and make bank selling that alum motor and buy a 5.3 and a 80e with the money haha
Old Sep 12, 2012 | 08:45 PM
sdimex's Avatar
sell the block and get a 5.3 and boost it .
Old Sep 13, 2012 | 06:06 AM
brentu2007's Avatar
lol. i'd like to stick with ls1 if at all possible, maybe see 600 HP. nothing is wrong with the motor i got now just packed alot of miles on it still runs like a champ. if i decide to stick with motor i got now whats a good setup to help get close to 600 hp??
Old Sep 13, 2012 | 08:46 AM
a4ls2goat's Avatar
This.
Old Sep 13, 2012 | 10:53 AM
HRHohio's Avatar
Depends on your budget... You'll probably not see 600 on stock bottom. I'd shoot for 500-550 max on stock bottom LS1...just my opinion.
Budget build:
Rear Mount
GT45 Turbo or On3 Performance 70mm Journal Bearing
Z06 Cam/springs
60 lb fuel injectors
AEM Tru Boost 2 Controller
AEM Wideband
Racetronix Hot Wire Kit
Wastegate/BOV
Front Mount Intercooler
Methanol Injection System
GOOD TUNE (Speed Density)
10 lbs boost
High Dollar Build:
Huron Speed Front Mount Setup
Turbonetics 76mm
Comp Cam 228/230/springs
60lb Fuel Injectors
Wastegate/BOV
E-boost controller
AEM Wideband
10 lbs boost
Replacement of Heads and Intake Manifold not really necessary with Stock Bottom. You'll max out your connecting rods before you max out your heads/intake.
Anyone else feel free to chime in / offer up adjustments. Of course this is but ONE recipe, like cooking... there are others.
Old Sep 13, 2012 | 06:18 PM
brentu2007's Avatar
I was planning on getting ls6 heads and cam combo. the budget build sounds pretty good considering this my first time building an ls1. the way every body talks on here seems to get very pricey. Sounds like a good setup for what i want. Can i use hp tuners to do a good tune or would it be better to have it done somewhere else
Old Sep 13, 2012 | 08:28 PM
pnykillerz28ls1's Avatar
if your worried about it being pricy then i would recomend selling the ls1 also. thats what im doing and with the money from that im getting the turbo and a motor with more potential.
Old Sep 13, 2012 | 09:28 PM
Bazman's Avatar
I turbo'd mine at 100,000 miles. Stock engine other than 222/226 cam. On a conservative dyno it makes 450rwhp with a loose converter at 6lb boost which would translate to an honest 550 crank hp. It is perfect for daily driving and I commute in it. I do have a very low back pressure plumbing on my rear mount with race quality headers, merge collectors etc plus I run water/meth injection to get more timing on pump gas.
Go for it, but you won't need 10lb boost and I would not recommend it on a motor with 180,000 miles. Instead run a mild cam and very good flowing plumbing, maybe some head work to get some power then run 6-8lb boost. It'll last longer than pulling 10lb every day in my opinon.
Old Sep 13, 2012 | 09:32 PM
brentu2007's Avatar
How bad is it to do a motor swap? U going with the 5.3? I just figured be alot easier doing with motor i.got in it than fighting with another motor
Old Sep 13, 2012 | 09:45 PM
brentu2007's Avatar
Awesome. Im gone try.it and hopefully she dont pop lol thanks for the info guys
Old Sep 14, 2012 | 10:56 AM
a-low's Avatar
Don't mean to hijack but what do you guys a ls1 long block with 120-160k miles can go for?
Old Sep 14, 2012 | 01:12 PM
JRENIGAR's Avatar
I started boosting mine with 172k on it. Car has 204k now dd'ing the **** outta it for over a year now pushing 9lbs. No meth, just 93 octane with 12deg of timming making #'s in sig in summer heat on the dyno @ 6000rpm where it shifts, no problems so far...
Old Sep 14, 2012 | 07:26 PM
brentu2007's Avatar
What setup are u running jrenigar??
