Thanks Speed Inc for the most impressive and reliable LS combo!
#42
Moderator
It had the stock lt1 feed and return(lt1's had return from factory) right under the firewall on a lt1 car you can disconnect the rubber line that connects to the steal line underneath. I used the speed inc quick connect fittings if you know what I mean? so it goes from the factory steal to the fitting to a steal breaded line that goes to speed inc fuel rails. I used a aeromotive boost referenced regulator
#53
since you had lt1 tank and lines, was your filter and boost reference regulator under the hood?
aren't the stock fuel lines atleast the feed line only a -6 steel line? Then the return would be a -4?
Why would everyone say upgrade to a -8 feed or better!
