budget 5.3, looking for 800 RWHP. What budget turbo to get there?
Or did you mean you don't think I'll be able to run that much boost safely?
Alright fellas, I don't mind if other questions are asked and answered in my thread, just so long as someone can answer mine as well.
Starting to wonder if I will be safe running in the 25-30 psi range boost wise just on pump gas and meth injection. What CR would yield this done safely? Boosted Firehawk made mention it can be done safely with CR as high as 10:1, but did not specify it would keep it safe at that boost level. Does anyone have any info on this? I've seen guys running the setup I am contemplating, but at 15#'s of boost or less on a consistent basis. What I would be doing is running 25-30#'s on a consistent basis. That's got to yield higher IAT's, and want to be sure its going to handle it safely.
Anyone??
Anyone??
I would run pure meth because it will knock the temps down better and will give that 93 more octane depending on the nozzle size it should bring the octane rating up to near 110. I run a M8 nozzle (800cc) buy a wide band and keep on eye on the air fuel ratio. Although putting that kind of power down on the street is another issue all together his car pretty much goes on kill mode at the track and then the boost is turned down for the streets.
That motor rode out like that for three years before it gave up. Theres another in it now it was and the new one are stock internals.
Here's a link to a new S475 from custom racing turbos. Cheaper than what you quoted above too.
Chris is a great guy to work with too and stands behind his stuff.
http://stores.customracingturbos.com...-T6/Detail.bok
Thanks for the info Preston. I want something rock solid reliable. Not something that probably could be done, but would be on the edge. I am also contemplating going with a 6.0 block instead of the 5.3 block. Price seems to be not much more, and gives more options on pistons and with the larger displacement, more boost may not be required to hit my power goal.
That being said, I think I might feel safer running a lower CR in at least the 9.5:1 or even 9:1 range. Any thoughts on this?
But if you are planning on building a 5.3 with rods and pistons you may as well buy a 6.0 and go that route IMO.
The 4.8/5.3 blocks are suppose to be stronger than the 6.0 blocks due to thicker cylinder walls. And most guys are using them because they are generally 1/2 the price.
I would say that you would be ok with that much boost and e85, but pump and meth I think you would be pushing your luck. But maybe a quality intercooler would make a difference.
And sorry for cluttering your thread before, just thought I'd share since they will be similar setups.
I'm all about a good meth injection and an intercooler. However, I am not going to hack up my front bumper so air flow to the FMIC will not be optimal. I will likely do the same thing I did on my Z28, and run an air duct from underneath to help direct air flow to the FMIC.
I don't want to go E85 because E85 has different blends. Meaning I will need to have a way of not only testing for the different blends, but adjusting the tune for them as well. It's just too much of a PITA.
So, I will do the meth, and FMIC and make the rest of the difference to keep me away from detonation with a lower CR. I am thinking 9.5:1 or 9:1 should do it.
I have a source that I can get both the 5.3 or the 6.0 for not much money at all. The difference between the two is about $100 from my source. At that point, it's just a matter of what would be better. So, unless you think I might be more reliable running more boost with the thicker 5.3, then I will go with less boost and the 6.0. Even with the 6.0 and less boost, I am guessing I still may need to hit 20 pounds or more of boost in order to achieve the 850 RWHP goal.
#33
Ricky, I am looking for 800-850 RWHP. Although what your selling may be a good deal, I doubt the smaller 72mm turbo you are selling will get me there. I am not even sure the larger S475 will do the job. I may need to go to an 80mm turbo to reach my power goals.
#36
Do you mind if I pick your brain a little? What setups were the 5.3's? And what RWHP did they make? Did it take E85 or race gas? If I can just see a few combos on the 5.3 with that Turbo making 800-850 at the wheels, it would give me more info that I need to start.
#37
e85 on a stock fuel rails Skinnies has done too. I was told 3 fuel pumps and only aftermarket rails, lines to the rails and a boost ref. regulator. Over 800hp on e85 and STOCk lines, which vendors and a few others say CAN NOT happen. He proved it with a few cars for sure.
#38
#39
My biggest thing is attaining my goal within the criterea listed (pump gas, meth injection, FMIC, 800-850 RWHP). I need to see a few combos on peoples cars that have done this, and see what their exact setups were.
I say more than one or two, because we all know how you can put almost an identical setup on two different cars, and end up having different results. Skinnies is the #1 highes RWHP 5.3 on the list here in the FI section, and he did 855. Other than him, there are only 3 other guys who have broke the 800+ mark out of the 5.3. When you have so few guys doing it (or maybe there are more that just haven't posted on the list), I find it possible that I may not be able to get there how I want to with running pump gas, and staying fairly inexpensive on the build. I would hate more than anything to copy someones setup, and then in the end with everything maxed, NOT attain my power goal. I want to be sure I can hit it, with little to no question. If I need to go bigger to the 6.0 I can. But if I can do it with a 5.3 and a PT7675 I would love to.
skinnies, if you get the chance, please let me know what the info was from the cars you spoke of.
