Copper Head Gaskets
Old Apr 10, 2004 | 04:24 PM
Zangel's Avatar
Fiery Features Director
Default Copper Head Gaskets
I was just wondering if anyone is using a copper head gasket. If so, which one are you using? I was looking at the Flatout Copper Head Gaskets with Rubber Coating. I was curious what people are paying for these and find out how they work. Just checking out all my options.
Old Apr 11, 2004 | 09:09 AM
stealth's Avatar
I use SCE copper .050 gaskets with copper coat.
Old Apr 11, 2004 | 11:46 AM
Zangel's Avatar
How often do you pull it apart for rebuilds and are you running pressurized water in the cooling system?
Old Apr 11, 2004 | 06:32 PM
stealth's Avatar
At least twice each year; stock radiator with electric water pump; water/water wetter.
Old Apr 12, 2004 | 06:16 AM
smokinHawk's Avatar
you have to replace the gasket each time right.
you have o-rings in them too?
how does everything hold up at that power level stealth?
Old Apr 12, 2004 | 07:10 AM
Reckless's Avatar
Super Moderator
Just finished a 408 for an ATI car using the Flat Out gaskets. The block was o-ringed and the heads have receiver grooves. Not fired up yet though.
Old Apr 12, 2004 | 09:48 AM
stealth's Avatar
9/16" head studs, orings, receiver grooves, copper coat and a .050 copper gasket has solved our head-lifting problems. But with too much timing and too much NOS, they will lift again.
Old Apr 19, 2004 | 11:03 PM
Zangel's Avatar
I got mine in today. We'll see how they work! I am a bit confused about the rubber coating though. I thought it would be a bit different.
Old Apr 19, 2004 | 11:09 PM
JoSeY's Avatar
Tiff....I am just gonna say that on the over 13psi boosted cars I've built, and then on Campbells old motor I swapped them out as well to make sure I didn't scorce anything in the combustion chamber.
We always used a non copper head gasket so JUST IN CASE we had any type of detonation it would probably blow the head gasket 1st and save the motor. I don't know if the same applies here but I wouldn't be a friend if I didn't say nothing. Take it with a grain of salt or whatever.
Old Apr 19, 2004 | 11:17 PM
1point3liter's Avatar
http://www.flatoutgroup.com/gaskets/techtips.asp
Old Apr 19, 2004 | 11:22 PM
JoSeY's Avatar
Originally Posted by 1point3liter
Well, like I said they seal very well...those are very nice head gaskets, wish I had them back in 99' when I was building my turbo motors.
Go for it Tiff....you should do great! Brian is an excellent tuner.
Old Apr 19, 2004 | 11:30 PM
Brains's Avatar
Dude, they've been around forever -- my Dad's 1974 Arctic Cat El Tigre snowmobile had copper head gaskets.. That goes back to the year of my birth, so I'm not claiming to know how long before then they were available though
Not many people have traditionally used 'em on street cars, due to the fluid sealing headaches. Lots of racers use 'em, wipe 'em down with solvent, spray 'em down with a little pookie of choice, and go at it. We're looking for the same combustion chamber sealing strength (incl. an o-ringed block) while also being able to reliably hold back the water. Mark @ FlatOut assured me he has several cars running these gaskets on the street with great success, and I'm sure hoping they work as well on Tiff's car
Old Apr 20, 2004 | 12:02 AM
JoSeY's Avatar
It's cool Brains, Like I said when I had the option of buying the metal gaskets for my Eclipse my reasoning was if I were to detonate that badly I'd hope that it took the HG and not my piston or valves....maybe that was dumb....but noone starts out knowing everything right? I've broken my share of things, but I've made some nice rides too...can't complain.
