Build Thread: 6.0 GT4788 4L80 S10 "Dropin Dime"
Well Finally got the DMV Nazzis to get my title to me ... Its all mine now HaHa Bitch's.. Ok enuf Bullshit.
6.0 Block
Stock truck crank
6.125 Eagle rods
4.005 Diamond 20cc Dish Dbl coated Pistons
Futral Cam
823 Heads
Holley Hi ram 102
GT 4788
4L80e Trans w/ 3200 Circle d Conv.
Truck:
2000 s10 Ext Cab
TRZ Upper and Lowers
QA1 coil over
Aero space brakes Front
9" Rear 3.55 gear Moser 35 spline axles and spool
Stock lincon versile rear disc breaks
Caltracs
still planning:
PCM
Fuel injectors
tuning software
cooling
Intercooler
6.0 Block
Stock truck crank
6.125 Eagle rods
Futral Cam
823 Heads
Holley Hi ram 102
GT 4788
Truck:
2000 s10 Ext Cab
QA1 coil over
Caltracs
still planning:
PCM
Fuel injectors
tuning software
cooling
Intercooler
295/65/15 MT DR .. Im getting them together on Photobucket right now . Im offshore working and will take more pics of the Parts later this week when I get back..
Ok guys here is a pic of the truck I should get some more after while when I get home... I have also second guessed myself on the GT4788 Im looking into a S480 For better drive-ability. Im also looking into a MS1 & 6010 like Denmah is Using. it looks hard to beat.. Boost management will be through a MSD Boost launch control. I already have it. As well as a Chiseled Ice/water tank and A to W intercooler....
Guys here are some more pics . I have managed to remove the bed and find a mess .. Its time to break out the buffing wheel and hit everything that gets in the way.. This is the 9" I found out when I went to pick it up it magically grew another lug and lost 2 splines per axle HHHHMMMMM?????? O well it only cost me a little chicken scratch . LOL . Ill just re drill the flanges for 4.50 BC It has the holes in the rotors for it already.. Ill have to change the gear also it came with a 4.10 and Im going 3.55 or 3.50 ... These are the front wheels magnum 2.0... As well as some Headers i got off EBAY... Ill try to do something with this.. Also my heads lurking under the bench..
