ATI Super Dampener Question
Old Apr 10, 2004 | 05:17 PM
BlackBootyZ71's Avatar
Default ATI Super Dampener Question
well, i just installed my ATI super dampener for my 8 rib ATI kit...and i had a question concerning how far the hub goes into the crank snout.
All of the pulley's/belts appear to be lining up (even with the ATI blower crank pulley on as well).
However, on the hub of the ATI dampener, there is a portion where the hub gets smaller in the form of a ridge...i have about 1/4 inch of the hub showing after that point (i know its hard to visualize, but i don't have my digi cam). The hub itself slid in a good bit after being boiled.
The stock crank bolt will bolt down now, but I want to be sure that the hub is in the entire way...does anyone have a closeup of their car with this setup?
Thanks so much,
-Mike
Old Apr 10, 2004 | 05:42 PM
kp's Avatar
kp
it sits further out then the stock balancer which sits almost flush - probably 3/16" or so. I thought the same thing when I put one on the first time..
Old Apr 11, 2004 | 06:35 PM
here are some pics...does this look right? Like i said before, the belts appear to line up, and if it were to go in to the ridge, it looks as if they may not be properly aligned...
Old Apr 11, 2004 | 08:00 PM
kp's Avatar
kp
that look about right, if you cranked the bolt to spec thats pretty much as far as it will go..
Old Apr 11, 2004 | 10:15 PM
cool, I wish I'd had today to work on it...guess i'll finish up next weekend! Hopefully the suprises for next weekend will be at a minimum!
