What type S/c For almost stock?
Vortech makes a kit too, but you have to buy their lil water to air aftercooler seperatly. Either one will give ya between 425-460 from 5psi-8psi....
Both kits come with everything you need for installation on a stock motor: supercharger, injectors, programmer, fuel pump.
No extra hardware needs to be purchased separately.
The kit with the aftercooler adds about 130RWHP on a stock motor. You can squeeze out more if you swap pulleys (although this voids the warranty).
you don't want to max out your cards, and blow the motor
Buy blower cash, and then have teh CC's to get you out of trouble if crap hits the fan.
Ryan
Its cheaper that route, and you'll be just as fast, at least in the short run.
Plus you can always add a blower/turbo later, if you plan your boltons right.
LT Headers, y-pipe, catback, rear gears, throttle-body, Fast Toys Ram-Air, LS6-intake, short-throw shifter, upgrade your entire suspension, install a blower-friendly cam, and blower-friendly heads.
An aftermaket air-lid, mass air sensor, and underdrive pulleys will have to come out when the blower goes in, so you might as well leave those alone, or at least hold on to your stock parts.
