6 Speed Guy's with 500 plus RWHP....
Old Apr 10, 2004 | 06:50 PM
98BLKMOBILE's Avatar
Default 6 Speed Guy's with 500 plus RWHP....
What are you launching @?
What clutches do you use?
What tires are you running?
Are there any modifications to your tranny?
I think I might have toasted my tranny.... again I'm trying to get a feel for what you are using to handle / manage the power on launch. Any info would be appreciated.
Brian
Old Apr 10, 2004 | 07:48 PM
MIGHTYMOUSE's Avatar
i run a spec stage 4 iron solid hub, z06 slave and a self made adjustable 277 master cyl.
my transmission was built by jim mattison (1gmman@comcast.net)
blueprinted with all the latest doo-dads and whiz-bangs.
tires are 27*11.5 hoosier qtp's
best short time to date is a 1.65 leaving at 3700 rpm's on a 2 step.
Old Apr 10, 2004 | 07:54 PM
Warbird's Avatar
Brian
I run a McLeod steel street twin
ET Streets 26"
My tranny is blueprinted with kevlar synchros and Stainless shift forks
My tranny has run flawlessly for 4 years with probabaly 150 5000 rpm hard launches at the track. If done right they can last a long time.
I also run a 12 bolt, chrome moly driveshaft and the torque arm is is mounted to the cross member. When things are moved off the tranny and the parts are stronger I think that will also add life.
Old Apr 10, 2004 | 08:59 PM
Thanks guy's... My tranny is stock, I have a strange 12 bolt and a Lingenfelter Drive Shaft. My master cylinder is also stock but I did the drill mod to it and that seemed to help a lot. Street wise I have never had a problem but at the track I drop it @ 6,000 +.... with slicks (I didn't start doing that until late last year and just now)...... guess I need some tranny mods... and a new MC... Is there someone that has tranny's already built for strip use that I could swap my core with & $$????
Brian
Old Apr 10, 2004 | 09:57 PM
eviltwins's Avatar
We just got a friends car off the rollers, he has a 64 Nova, 422 inches (4.1 x 4), running a D2R blower through a T56. Put down 1015 RWHP and 888 RWTQ, clutch was a mcleod street twin. Awesome street manners with that clutch, I was running one too when I had a stick.
Old Apr 11, 2004 | 06:53 PM
GueSS Who's Avatar
I ran a spec stage 3 ceramic disk with a stock flywheel,presure plate,master, and slave. I was launching at about 4 to 4500 rpms on a 150 shot. I was using 26/10.5/16 ETstreets. I had a stock tranny with a pro 5.0 shifter and a lou's short stick.
Best time was 10.50 @131
550rwhp and 575 rwtq
Old Apr 11, 2004 | 10:02 PM
PurEvl's Avatar
spec 3 here brian...just put it in on saturday
Old Apr 12, 2004 | 07:05 AM
Noyzee's Avatar
8 second mod
ESP t56, specc 3 last year, spec 5 this year. leaving around 5k last year, 2 step set for 4600 for the first time out this year( hoping to be this weekend.)
Tranny and clutch both fine after all last years abuse!!
Old Apr 12, 2004 | 07:34 AM
PurEvl's Avatar
so last years abuse was all spec 3 with the 575 rwhp right? Thats good to hear.
Old Apr 12, 2004 | 01:01 PM
Noyzee's Avatar
8 second mod
yes, about 10k street strip miles, power shifting, speed shifting and yes miss shifting. all spec 3
575 was peak. it was an honist 550-560.
the clutch and tranny both mint. clutch show some wear but i couldnt believe it held.
Old Apr 12, 2004 | 04:19 PM
Brad... don't you have the modded Eastside tranny??? I'm looking into one of those now...
Brian
Old Apr 13, 2004 | 07:34 AM
Noyzee's Avatar
8 second mod
Yes I do. I pulled it out do to the fact i screwed up on drive shaft size last year. it was short so it was loose on the tail shaft and ait it up a little.
They took it apart to inspect it and replace the shaft and the rest of the tranny was mint. if i didnt screw up the size, im sure it wouldnt have come out.
