Making my car leave harder?
Like you said, there's more than one way to skin a cat. I have people vehemently telling me that pulling timing all the way down and using that method on the two step will do exactly what I want it to do. I'd be doing it right now, but I'm waiting for my crossover manifold gaskets to come in the mail first.
Oh, and thanks for being a tape recorder!
Does your car have a hand ebrake? If so use it to help hold the car, it was worth 3-4 psi on my old setup.
Would you rather just use heat from unburnt fuel to spool the turbo?
Or would you rather:
Raise cylinder pressure
Increase exhaust velocity
and raise the heat from leaning out the AFR and adding timing
I know which method I'd rather use....IMO pulling all the timing out is for clutch cars that's it. Because they cannot load the engine on the starting line to build boost, they only have one option and that is to do what they are telling you to do.
You have an auto. You can create load where they can't. Using load, increasing exhaust velocity, raising cylinder pressure and increasing the heat in the chamber from leaning out the AFR and adding timing will always spool faster than just pulling out all the timing in an automatic car. Note I said in an automatic car and not both.
Will pulling all the timing out in an auto work.....probably, but it will take a lot longer I guarantee than adding timing and leaning it out. I don't think you'll ever be able to get any boost built by pulling the timing out and if you do it will take so long that you will end up probably cooking your transmission fluid before it's over with.
Put the AFR in the low 13's when you're in vacuum trying to get some boost going.
Once you get some boost going(1-2psi) add fuel to the mid to low 12 range and let the boost continue to build as you slowly increase the amount of fuel being added. Once you get 4-6psi built wherever you're able to do that in whatever RPM range, set the two step for that rpm and have it set-up in the tune to when you hit the two step throw fuel at it to get it into the 11.2-11.4 range and pull 6-12* timing out of it then.
Once you get the turbo's going and get some shaft speed, THEN you move the combustion out of the chamber and into the crossover and merge piping by pulling timing. That is why the clutch guys do it to move the combustion event closer to the turbine and when it does light off the exhaust pulse is MUCH stronger and closer to the turbine making it spool harder and faster.
By adding fuel to it around 4-6psi in your situation you're going to make the combustion event bigger and more powerful with more fuel. Add to that it being closer to the turbine now by pulling timing out of it and moving it into the crossover, and you're going to be doing the exact same thing. Only you won't spend 15 seconds trying to spool before you can even move into the second staging light while your trans fluid is cooking like a stove pot at a crawfish boil.
I would use no less than 36* timing initially to get it into 1-2psi of boost, then bring it into the 26-28* range once you get 1-2psi. As the psi climbs to 4-6psi bring it down to 20-22*. Once you hit the two step limiter pull at least another 6-12* out of it(whatever you find makes boost faster) and throw fuel at it in the AFR range I mentioned.
All wide bands will show a false lean from un burnt O2 in the exhaust because the 2 step drops cylinders when activated.
This is awesome info though, makes complete sense.
http://www.youtube.com/watch?v=m0M0P...ature=youtu.be
stock 60e
3700lbs
stock suspension
275 nittos
leaving off idle
393rwhp bolt ons 228r.
373 gears.
93* tune
1.66 60 foot ---7.38 in the 1/8th
Koolrays is running one with a 1% loss. and it was that way the first time they sent it to him.
good luck man. fast car you have there.
