Twin 6262 T/A - Turbo Joe twin kit/ 370cid 6sp street car
#203
I ran them all last season with no problems with my single 76mm. My buddy has them in his car ran a 150 shot for 2 seasons and now boosts it. He also beats it hard and puts it away wet. Reconsidering would involve taking apart a running motor lol. If it eats one I'll just switch out to diamonds or Wiesco. At this power level it's not a matter of if, it's a matter of when. Ugh.
Long as he stays 20psi or less, he shouldn't lift a head. Im going for the same power goals on a 390 and brian and I at AES figured up, that In a perfect world, 16.87psi should make 1000rwhp on a 390. They did some testing, and they see the LQ blocks start to push water at the 22.5ish psi range on a 4 bolt setup. He said it expands the cylinder walls more than it lifts the head. Words from AES.
#209
Looking good, I personally would v-band the entire cold side except the compressor and throttle body.
Fixing blown couplers on the side of the road is no fun, even with the piping bead rolled those clamps can only hold so much.
#213
Ken, you gotta see some of the other builds we'll have going on! All i can say is theres a few twin kits in the works.....oh and that our chassis fab guys are great! you gotta see the wild stuff they come up with!!! second to none!
#219
