What size turbos for a rear mount twin, high comp, low boost 434ci engine?
Toying with the idea of selling my 350z and keeping the engine and swapping it into a C6 chassis. The engine is an 11.8:1(would bring it down to low 11s with the proper head gaskets) 434ci sleeved block stroker with TFS245s. It would be a rear mount setup and id be running a built A6 transmission.
I want to run a low boost meth setup (something <10psi) and wondering what size turbos would work well with this setup?
