Turbonetics NEW 7675 and 7875 Turbos AVAILABLE through Huron Speed!
#541
Back up, supplies becoming very limited!!!
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic36191_1.gif)
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
#543
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
Shoot me a PM and we can work it out!
__________________
#544
Back up, hope everyone enjoyed their weekend!
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
__________________
#545
PM me for the VERY best pricing on these units!
__________________
#547
How much boost and details on the rest of the set-up?
__________________
#548
I was on spring pressure only going through my exhaust. Log showed 10-11 psi, 1-2 shift happened at 5300 trying to keep from spinning and I never went above 60% TPS in 1st gear. I tried turning it up a bit on the last pass but blew the tires off and ran a 12.0 @ 137. Needless to say, I am damn happy!
#549
Stock bottom end early year LQ4, Speed Inc. TU1, Turbonetics 7875 1.15 ar, JGS 40mm wastegate, stock 4L80e with HD2, Circle D 3500, 3.23 10 bolt that leaks and whines, E85. I was on 295/55/15 ET Street Radials that are on my 17/15 Dark Star combo.
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
__________________
#550
I have one lone ranger left in stock, who wants it?!?!?!
Billet 7575, 1.15 a/r
__________________
#551
We have MORE of these 75mm turbine wheel'd units on the way for stock!
-Cast Wheel 7875, .96 a/r, Oil only
-Cast Wheel 7875, 1.15 a/r, Oil only
-Billet Wheel 7575, .96 a/r, Oil only
-Billet Wheel 7575, 1.15 a/r, Oil only
These units will be in stock this week and ready to ship, contact me for a great deal!
__________________
#552
What kind of times and power are you guys making on the 7675/7875s? I have a TC76 and am thinking this might be a worthwhile upgrade even at the same boost levels to help the motor breath a little better. Considering it's basically direct replacement for the TC76 the choice seems easy.
#553
__________________
#554
7875's IN-STOCK! PM me to get yours today! ![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Jon
Jon
__________________
#557
#558
I have the. 96 ar, 6.0 stock heads, ls9 cam, meth, built 4l65,3600tc,and 14lbs boost. I cut a 1.76 60'. Horrible, but it worked. Stock 20s,tailgate off. I believe it's around 5600-5700 race weight.
#559
How come you have not posted any dyno graphs showing how the new 75mm turbine out flows the smaller wheel?? Did these turbos in fact not make any more power? With the same commpressor size?
#560
We do not have a dyno in house, nor a back to back comparison up to post. However we have these turbos on SEVERAL cars now with noticeable gains in power at the same PSI levels as well as drastic reduction in drive pressure from smaller turbine wheel'd turbos.
If you read back through this thread you will find other customers as well very impressed with the switch from smaller turbine wheel'd turbos to these
__________________
