POOR man's low slip converter?
right now im at like 30% slippage due to shifting at 5900. i added a cam to get me to about 6800 but also increased the compression a point. now, the stall is higher
the engine has so much torque that it goes straight to 5000rpms and 10psi in less than 1 second does anyone have knowledge of the following and why they would or would not work:
1. stockish, heavy, 12" converter
2. very low stall circle track converter
3. torque converter eliminator(direct drive)
4.other.
thanks
redneck(now out of business) turbo converter. it ran 6.0 at 114 last year with 14 percent slip at 7400rpms. this year, 6.0 at 114 with 30% slip, 5900 rpms
I went from sae 48?? low viscosity hydraulic fluid(similar to regular auto trans fluid) to now a mix of jd hygard(approx sae 68) and mobil dte heavy sae 100!! hydraulic fluid.
I think the engine responded on the low end just too well to the extra point of compression
pm replied. thanks man. what kind of improvement did you see?
my redneck converter was slipping 32% as stated, at 5900 rpms. I had a hunch that if I raised the rpm, it would tighten up.
so I added a decent cam and made a pass. Even with a best ever mph, the same converter is only slipping 12% at the eighth at 7600 rpms.
