my turbo set up
Originally Posted by NoGo
Very nice. Really good looking fab work. Are you guys bending your own or working with pre-bent stuff and just chopping accordingly.
mark
That is looking awesome. I was looking into those kits but it seemed that the whole setup is fairly expensive. I may still save up for a kit car project but I'll probaly use this chasis instead http://www.factoryfive.com/table/ffr...TM/GTMkit.html not as radical but still pretty sweet. With a turbo LS6 or LS7 (if available by the time I get the money together) it should take most corvettes and stock vipers for a walk.
Originally Posted by LiquidSnake
mkoch1: Are you using a 996 Transaxle?
mark
Another update. Exhaust is basically done, just need to go over some of the tach welds and send it off to be jet hot coated.
larger image
larger image
mark
![](http://www.markkoch.net/images/canam/exhaust/s_exhaustFullWeld1.jpg)
![](http://www.markkoch.net/images/canam/exhaust/s_exhaustFullWeld9.jpg)
mark
#32
That is just too cool. I love how the center pair of exhaust are dedicated to the BOV. You have got to be loving this buildup Mark.
Thanks for the updates.
Mike
Mike
#34
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
mark
#36
Originally Posted by mkoch1
We did it this way so the wastegate would respond better. It will also be nice because at idle and part throttle everything will pass through the muffler and be rather quite. When you floor it the wastegate will dump into the air and be very loud, letting others know to get the hell out of the way.
Have to see how much fire comes out the pipes, don't want to melt the fiberglass.
mark
mark
Ooops yeah I meant to say Wastegate. I didn't even think of the muffler routing. Very cool idea. You could also route an electric cutout to the same set of center pipes. The possibilities are limitless
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Mike
#37
Well, the beast has left my garage and is now in mkoch1's garage again. I'm the guy that did the headers and exhaust system on his car. It was cool doing the headers and exhaust system and it should look great when it is all Jet-Hot coated.
His car is just awesome.
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
