Intercooled vs straight pipe???
http://www.yellowbullet.com/forum/sh...d.php?t=369562
You can also do direct port meth if you wanna be cool
My IAT on a normal 64-68F day range typically from 82F to 97F during highway driving with the higher number reached under boost or around town. If in city traffic, that can climb to 115F, never seen it higher than 125F, but not raced it yet either. I use twin nozzles for a 50/50 water/meth mix.
As you are running much more boost than me, I'd be thinking of a big front mount plus water/meth as other have suggested. Alternatively a multi staged system.
Best nozzle placement is after blower but before throttle body - at least 12" away or more if possible to give it time to mix with the air and go in evenly (ie. too close and you can get uneven mix to some cylinders which could bring on detonation in the cylinders not getting enough).
is bloody good and I will now shut up
I'm planning on trying out the meth injection rather than an intercooler, but I'm still a long way from getting any results.
and nitrous is around -125*f (where nitrous boils [changes from liquid to gas]) @ the solenoid when spraying.
And sraying water/meth (a liquid) into a compressor will also artificially increase the compressor map as it will give the compressor wheel more surface area....similar purpose of a batmowheel
