which turbo would you run.
Old Nov 28, 2012 | 05:18 PM
LilJohn's Avatar
Originally Posted by T76s10
What's wrong with the tu1 cam?
Nothing if he uses something like a 7675... or an On3 76.
If he runs the s400 with a 96mm turbine that camshaft isnt agressive enough on the exhaust lobe, specifically the EVO, to drive the turbine up at its capacity. In other words.. itd be laggy.
Old Nov 28, 2012 | 05:22 PM
Atomic's Avatar
I need a gauge for that
Around 120lb/min
Old Nov 28, 2012 | 05:28 PM
T76s10's Avatar
Ok thanks for clearing things up john. How about the tu2 on a lq4? Does that have enough evo to push a 96mm turbine wheel say 1.32 ar? Sorry to thread jack. Thanks atomic, you might be seeing a pm at Some point.
Old Nov 28, 2012 | 06:05 PM
LilJohn's Avatar
It does depending on what intake centerline you install it on.
But that cam has another issue... too much overlap. The 112.5 lobe seperation is a touch too narrow for efi applications in my opinion. Its got 11 degrees of overlap at .050... I target 2-5.
For a 6 liter and that turbo... i do 230-232 on intake and 238-240 on exhaust.
Old Nov 28, 2012 | 07:09 PM
T76s10's Avatar
Pm'd you John
Old Nov 28, 2012 | 08:06 PM
71 chevy's Avatar
The tu1 or tu0 is what i would use, regardless of cam.they will make torque, helps you spill faster, and keep a decent rpm range.you go a little too big on the ivc and evo and you are killing spool
Old Nov 28, 2012 | 08:25 PM
71 chevy's Avatar
im using a single pattern similar to the tu2, but a little less duration. it lopes at idle, but it spools ridiculously fast(10 psi on the transbrake takes 0.8 seconds,as i said, sick fast), but will rev all the way to 7600, so it is a little big.
the tu2 will actually act a little smaller than my cam though, because the 112.5 lsa has the intake valve closing a little earlier, for a little more dynamic compression. it would work in a heart beat, but be prepared for the engine to rev.
Old Nov 28, 2012 | 08:53 PM
T76s10's Avatar
im planning to run turbos similiar yours so thats good news, i want fast spool with this build. i seen the youtube vids on your chevelle and that thing launches pretty damn hard. i figured i better go a little big with this cam since i plan on building this motor in the future. thanks
Old Nov 28, 2012 | 09:05 PM
LilJohn's Avatar
Since when does lobe seperation angle have anything to do with when the intake valve closes??
Intake centerline dictates that. Lobe seperation is the relationship between intake and exhaust centerline.
Lobe seperation dictates nothing about the intake valve events.
Old Nov 28, 2012 | 09:12 PM
LilJohn's Avatar
Too late of an IVC can affect spool... it reduces dynamic compression.
But how in the hell can opening the exhaust valve EARLIER, at a higher cylinder pressure obviously, hurt spool? Especially considering turbine wheels work off of pressure...
Old Nov 28, 2012 | 09:38 PM
71 chevy's Avatar
I'll play your game.
tu2 cam, 236/236 112.5 lsa, no advance
x cam 236/236 116 lsa, no advance
which cam closes the intake valve later???
answer that and you have the answer to your question "Since when does lobe seperation angle have anything to do with when the intake valve closes??"
lets think about this for a second. what is cylinder pressure? cylinder pressure is what does WORK and moves the crank. you open the exhaust too early and what happens to the cylinder pressure?
if some is good and more is better, why dont we just have an evo of 90, or even more?
also, what happens to durability of the exhaust valve when we start opening it too early against extreme cylinder pressure?
Old Nov 28, 2012 | 10:07 PM
  #32
71 chevy's Avatar
thank you sir.
i prefer to go a little smaller than a little bigger on cam selection. but thats a personal preference based on having too small a cam and too big a cam.
Old Nov 28, 2012 | 10:14 PM
  #33
LilJohn's Avatar
Dude... really?
In both those cams the intake centerline, lobe seperation and exhaust centerline are all th same because theres no advance specified.
Again lobe seperation angle has Nothing to do with the intake valve events.
You just posted examples where the icl is the same as the LSA.
Considering they are the same since no advance was specified its pretty damn obvious the tu2 closes the intake valve 3.5 degrees sooner. Its intake centerline is 3.5 degrees advanced from the other cam.
Try again.
Old Nov 28, 2012 | 10:21 PM
  #34
Gfleck047's Avatar
I will talk to a few engine builders see what they say about a cam... the turbo I think il be going with a s475 on that note who does everyone recommend to purchase a turbo from
Old Nov 28, 2012 | 10:24 PM
  #35
71 chevy's Avatar
Dude... really?
dude... you design cams . I would expect you of all people to know camshaft spec convention.
ie. 236/236, 115(no advance specified) means lsa is 115, icl is 115 and ecl is 115
and 236/236, 115+4 means lsa is 115, icl is 111 and ecl is 119
seriously... if no advance is specified, then the icl = the lsa, if installed straight up. i know you know this.
Old Nov 28, 2012 | 10:30 PM
  #36
LilJohn's Avatar
So since the LSA and ICL are equal all of a sudden the LSA dictates the intake valve events??
Your last post just repeated what i said.
Intake centerline is what affects the valve events. Period.
Old Nov 28, 2012 | 10:44 PM
  #37
71 chevy's Avatar
i guess i should clarify, since not everyone reading it knows the convention, and i dont want to confuse anyone.
LSA does not dictate when the valve closes, the ICL does that. however, when a cam is advertised with no advance figure, eg the tu2 I referenced, then the LSA,ICL and ECL are all the same number when installed straight up.
Old Nov 28, 2012 | 11:21 PM
  #38
code4's Avatar
forcedinductions.com
Old Nov 28, 2012 | 11:28 PM
  #39
qqwqeqwrqwqtq's Avatar
So you've tested EFI turbo combos with more than 2-5 degress overlap @.050 and lost power?
Interesting, as that is not consistent from what I've seen on the dyno and the track.
Old Nov 29, 2012 | 01:56 AM
  #40
LilJohn's Avatar
3 cams...same engine, car combo etc etc.
0,5,10 degrees of overlap. Ivc and evo the same on all 3.
Cam with 5 picked up over the cam with 0.
Cam with 10 picked up over the cam with 5....BUT it was less of a gain than the 5 had over the zero. In addition the fuel needed was more. So again IN MY OPINION we found the point of diminishing returns for what we were doing.
How long we gonna dance this Dance?
