Procharger questions
Old Dec 3, 2012 | 12:12 AM
sweet99ss's Avatar
Default Procharger questions
Okay I have some procharger questions. Piecing together a kit...
1. With a 6 rib kit is a new harmonic balancer needed? or will a stock or 25% u/d crankshaft pulley be fine? Will the belt run right off the pulley?
2. What all will I need for an 8 rib setup if I were to go with that? Is there a special crankshaft pulley you buy?
What all will I need to complete the kit?
Old Dec 3, 2012 | 06:21 AM
ramairetransam's Avatar
you need a j brakcet , intercoolers, or intercooler , new harmonice balancer for 8 rib , dont go 6 rib , i have it and want to change over to a 8 rib setup .
if you go 6 use the stock balancer and the 6 rib bolts onto it .
Old Dec 3, 2012 | 06:39 AM
dschmittie1's Avatar
Here I think this simplifies things some. With 6 rib you need to run the stock balancer.
2 run 8 Rib you must buy a ATI superdampener.
To upgrade from 6-8 rib you need the ATI dampener, crank and blower pulleys and new stand offs.
Hope this helps
Old Dec 3, 2012 | 12:32 PM
sweet99ss's Avatar
Would a 6 rib support 6-8psi?
Old Dec 3, 2012 | 12:51 PM
yes but not much more without some belt slip issues
Old Dec 3, 2012 | 01:23 PM
sweet99ss's Avatar
Thanks man your great help! How about the 4.5 twin intercooler kit? Is this good?
