Our Shop Car 427/88mm setup
#53
Don,
Do you run double adjustables in the rear? What tire pressure on that pass? Front travel/pitch rotation looks perfect, I'm thinking you didn't have enough compression setting in the shock though maybe? Tire looked wadded up a bit only reason I ask.
Great numbers.
Great numbers.
#56
1/8 did 5.5 at 134.
Compression is 3/4 tight. I know what needs to be done. Problem was we were testing alot of stuff and finally doing license passes. I'm also the one that does suspension setup,so I have to see the vid's to see whats going on. After seeing that I know what needs to be done.
Next time out we'll vid each run and I'll go from that.
