what to do next...
Jose
what kind of power are those turbos rated for.
build the motor low compression alot more streetable and you can run alot more boost on pump gas . also a lower compression motor will make more peak power.
how much boost are you running? have you dyno tuned the car?
nothing is more important than the tuning make sure that after every mod you go back to the dyno and check your air fuels and you power output.
I would work on the fuel first, then maybe look into some 6.0L 73cc chamber heads to lower the compression, and a nice turbo cam
