Something went wrong, ticking and smoke...
Old Dec 28, 2012 | 02:00 AM
SirNemesis's Avatar
#1: 160psi
#2: 159psi
#3: 158psi
#4: 155psi
#5: 80psi
#6: 162psi
#7: 159psi
#8: 155psi
Old Dec 28, 2012 | 02:09 AM
itsslow98's Avatar
Originally Posted by SirNemesis
#1: 160psi
#2: 159psi
#3: 158psi
#4: 155psi
#5: 80psi
#6: 162psi
#7: 159psi
#8: 155psi
Leakdown will tell you where that pressure is going.
Old Dec 28, 2012 | 04:10 AM
SirNemesis's Avatar
It has to be going down, its the only thing that would explain the smoke and crankcase pressure. I've started work on the stripdown, should have the head off tomorrow morning.
Old Dec 29, 2012 | 12:23 AM
SirNemesis's Avatar
Pulled the head, can't see a problem.
Piston looks fine, gasket was sealed perfectly. No pitting, no marks, no scratches or cracks. Spark plug was also fine when I pulled it. Carbon matches all other pistons, cleaned off easily.
Haven't pulled the valves, but theres no marks on the head to indicate a problem. Will get the tools and pull them out tomorrow hopefully.
Old Dec 29, 2012 | 03:42 AM
SirNemesis's Avatar
Appears I was wrong...
Old Dec 29, 2012 | 03:56 AM
80gus's Avatar
that sucks! hope its a cheap replacement for ya.
Old Dec 29, 2012 | 04:09 AM
SirNemesis's Avatar
Ohh, there isn't really many cheap options left for me at this point... It's going to be costly...
Old Dec 29, 2012 | 08:00 AM
I8UR4RD's Avatar
wow. that is not quite what I was expecting
Old Dec 29, 2012 | 08:01 AM
SirNemesis's Avatar
Me neither...
Old Dec 29, 2012 | 08:24 AM
9sectruck's Avatar
WAS this a stock production ls2 with stock sleeves?
sorry if I missed that detail.
Old Dec 29, 2012 | 08:25 AM
SirNemesis's Avatar
Yeah stock L76/LS2 block + 30thou oversize.
Old Dec 29, 2012 | 11:47 AM
  #32
I8UR4RD's Avatar
do you think it may have spiked at some point? wish aluminum was a little more forgiving. Looks like you will have to pull it and have another machined. It wont be that bad if you can assemble it yourself. I think a block can be had for 300-500 and an honest machine shop can clean her up and hone it for 1000-1300 ish usually.
Old Dec 29, 2012 | 01:15 PM
  #33
stevieturbo's Avatar
Is 30thou safe on an LS2 ?
I know my current block is only 0.005" and will be doing likewise with my next one.
I want the liners as thick as possible.
If all other parts are good, all you need is another block, so the financial cost shouldnt be too bad.
Although I'd seriously consider keeping any pistons/block as close to a factory bore size as possible to retain strength.
Although that's pretty **** damage...at least you found the problem.
Old Dec 29, 2012 | 02:13 PM
  #34
slowride's Avatar
Guys have done .030 over before, but it's probably pushing it with that kind of power. Most I've seen at that overebore were NA also. You could send it to ERL for a superdeck deal, but I'm sure shipping would kill you unless you just send the block.
Old Dec 29, 2012 | 05:52 PM
  #35
SirNemesis's Avatar
It must have spiked at some point, I just don't know when. I'm generally pretty safe with my tuning and really haven't been pushing it that hard.
I wish it was that easy, stuff is alot more expensive in Australia. I've priced up an LY6 block at $1500 AUD (AUD and USD are pretty well 1:1 at the moment), + $800-$1000 in machine work + new bearings and gaskets. Won't be a cheap process and I really don't have that kind of cash at the moment.
I was assured at the time that 30thou would be OK on an LS2 block, the liners are thicker from standard compared to an LS1. The problem is the block had about 10thou deep damage from a previous failure, so the option was go 30+ then or bin it. I got 25,000km's out of it and 2 years, so it wasn't all so bad I suppose. Borrowed time...
I knew it wasn't going to lasto forever, I always just wanted it to give me a sign before it detonated all over the road, so I could save the rotating assembly. Looks like I can salvage everything except the block, so thats pretty good I suppose.
I looked into the ERL option as I'd much rather sleeve this block than replace it with an iron block, but unfortunately that process will cost me roughly $4000AUD by the time I get it back in Australia.
Old Dec 30, 2012 | 03:34 AM
  #36
If that's split right down to the base, I wouldnt be re-sleeving. I dont trust re-sleeved blocks at the best of times.
Of course the other option is iron
Old Dec 30, 2012 | 03:40 AM
  #37
SirNemesis's Avatar
The crack is only about 8mm deep down the bore that I can see, but I'll be going iron regardless. Sleeving it just too costly in Australia.
Old Dec 30, 2012 | 03:49 AM
  #38
It's not much fun in the UK either. Everything has to be sourced from the US and ends up costing a lot of money.
Still cheaper from the US than anywhere that has anything in the UK would sell for though. There is only a small selection of cars that use the LS platform here, and they are all Aus imports. At least you guys get plenty of LS based cars in Aus
Old Dec 30, 2012 | 03:52 AM
  #39
SirNemesis's Avatar
Yeah plenty of LS powered cars here, but 2:1 markup. Generally its significantly cheaper to buy from the US including postage than it is to buy locally. The sad part is, you also generally get a response faster from the US AND the product arrives faster than buying locally...
Old Dec 30, 2012 | 05:15 AM
  #40
Mista Blazer's Avatar
Well.. this was a complete flop.. not what i would of imagined.. i was thinking of blown rings. especially from cylinder #5 giving such low pressure. sorry to hear about this bud. wish you the best of luck and keep us posted!
