flywheel choice
Old Dec 11, 2012 | 11:24 PM
DirtyBird310's Avatar
Default flywheel choice
Need advice for what flywheel would be best right now i have aluminum flywheel im wondering if i should do the iron flywheel instead if im boosting your guys thoughts on this could help me out alot thanks
Old Dec 27, 2012 | 09:21 PM
Athlon2k2's Avatar
Any benefits of aluminum in a boosted setup. I know on imports it is common for quicker spool times. Not sure about the V8s.
Old Dec 27, 2012 | 09:44 PM
jridenour31's Avatar
I prefer steel. Just seems easier to drive the car with an aggressive clutch with a heavier flywheel.
Old Dec 27, 2012 | 10:12 PM
Thanks guys appreciate the input
Old Dec 29, 2012 | 05:17 AM
Ls-x's Avatar
i will advice you to go with the steel one because the f-body is a heavy car compared to others so you can get better 60' times.
good luck with the build .
Old Dec 29, 2012 | 09:22 AM
Athlon2k2's Avatar
One good question that is important is how do you plan on using this car? DD, track, drag?
