Oil for fi
Old Dec 12, 2012 | 11:45 AM
sprayedenali's Avatar
Originally Posted by o2camaross
I also like Rotella T6 5w-40. It's relatively cheap, but still has a good amount of zinc. I've been using it in my turbo truck and also started using it in my stock 2010 LS3 camaro. In fact, about 3 weeks ago o'reilly's had a sale on it, $20/gallon!
go to walmart, their oil, and really any fluid, is much much cheaper!!
Old Dec 12, 2012 | 11:49 AM
9sectruck's Avatar
Autozone, orileys carry's vr1 oil
Old Dec 12, 2012 | 05:43 PM
combs_425's Avatar
I put in 6qts but it shows that the oil is still low. Do I put in another qt? Is it low because of the supercharging
Old Dec 12, 2012 | 05:58 PM
combs_425's Avatar
Ok 6.6 is the capacity
Old Dec 12, 2012 | 05:59 PM
Tally TransAm's Avatar
run rotella T6 in the new setup.
Old Dec 12, 2012 | 07:20 PM
I8UR4RD's Avatar
a buddy and I were just talking and we had discussed the Synthetic Vr1 not being used in Turbo applications because it broke down alot quicker since the oil gets much hotter feeding thru the motor and turbo.
Can anyone dispute that?
Old Dec 12, 2012 | 08:19 PM
JAX04's Avatar
Rotella 20w50 here
Also, maybe its just me and a few of us around here, but seems like since we started using E85 full time, the oil is thinner
Old Dec 12, 2012 | 08:56 PM
Wicked69's Avatar
Originally Posted by Slowhawk
I wouldn't use 20w/50 in engines where it's cold weather. Oil gets thick,too thick up here. I suggest the VR1 40 weight in all my motors and switch to Mobile 1 0w/40 which still has zinc in it.
I have been running the Mobile 1 10w-30 full synthetic. Which one do you prefer for a street and strip car. Mine is daily driven but I rape that bitch all the time. Would the VR1 40 or the Mobile 1 Ow/40 ( I assume full synthetic)?
Thanks.
Old Dec 13, 2012 | 06:45 AM
ZL1Killa's Avatar
some some 0-40 or 10w-40 is actually in my opinion better than the 20w-50. if you look at the oil basic info that most manufacturers present, you will find the -50 oils are like roughly 20 cSt rating... this is like molasses compared to -30 oils @ 11. (maybe not quite that bad)
but a 10w-40 or 0w-40 has a cSt of around 14, and if you can find it with the zinc+Ph amounts around 1100~1300 (versus 5w-30 mobile 1 @800~900) you are doing good. if not purchase the zinc+ph additive and add 1/3 of a bottle.
the only idea I see of using 20w-50 (such thick oil) is if the car would see a lot of dragstrip + hard passes. I drive my car on the street 90% of the time and it sees maybe a couple true hard passes a year. The 20w-50 works at the dragstrip as it is thicker at the base temperatures of 100C rating and is also thicker at higher temperatures versus 5w-30. its all about temperatures.
i haven't messed with it yet but have thought about blending 20w-50 with some 0w-40 and doing some oil & viscosity tests
Old Dec 13, 2012 | 07:32 AM
edge04's Avatar
What is the harm in being thicker? Aside from colder weather
Old Dec 13, 2012 | 08:37 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
Being thicker, it is tougher to pump at startup, especially in cold temps. Sure you have lots of psi of oil pressure, but it's flow that protects bearings.
I had all of my bearings coated and my car stays in the garage during the winter, so personally, I'm fine with running 20w50 because the oil rarely ever gets below 50 degrees, but if you have a car that's outside, or sits parked outside for extended periods of time, a thinner oil during the winter would help at startup.
Old Dec 13, 2012 | 08:53 AM
  #32
Wicked69's Avatar
Aren't you supposed to use the oil for the clearances you have? I would think a 50 weight would be too thick for the clearances in most of the LS engines. NO?
Old Dec 13, 2012 | 09:37 AM
  #33
edge04's Avatar
That's what I thought. I too have everything coated and my car sits in a heated garage and doesn't come out once snow hits the ground.
Old Dec 13, 2012 | 11:35 AM
  #34
combs_425's Avatar
Even after putting 7 qts in I'm just above the add mark! Is this normal? Should I put in more?
Old Dec 13, 2012 | 11:37 AM
  #35
combs_425's Avatar
I also put in 20w-50 idk if it is me but I seem to have more drive train noise.
Old Dec 13, 2012 | 12:35 PM
  #36
edge04's Avatar
Stock pan and dipstick? Oil cooler?
Old Dec 13, 2012 | 01:50 PM
  #37
combs_425's Avatar
Yes stock dipstick and oil pan
Old Dec 13, 2012 | 03:41 PM
  #38
combs_425's Avatar
Lol I found the oil cooler
Old Dec 14, 2012 | 05:58 AM
  #39
roninsonic's Avatar
To the guy talking about 0w40 and similar weights of oil- Big spread oils are VERY prone to shearing due to their additive package unless you want to shell out big $$$ for an ester-based synthetic, especially when worked hard in an application like, say, a high-HP LS street-strip car. 20W50 will resist shearing better, and will be just fine in most applications as long as you let the car warm up before you take off like a bat out of hell. Also, a lot of engine builders use looser tolerances than factory, so a thicker oil is a better fit.
Old Dec 14, 2012 | 06:29 AM
  #40
UNDER PRESSURE MOD
I couldn't agree more. In a factory built motor with tighter bearings, sure a 5/10w30 is fine, but in a built motor, with slightly looser bearing tolerances (which most forged motors are), having a slightly thicker oil is a good thing.
