626hp 800+Tq!!
Old Dec 12, 2012 | 10:10 AM
therealthatguy's Avatar
Default 626hp 800+Tq!!
Recently purchased a 98 mistic teal z28 for a steal.
Car was already set up with a 5.3lm7 built t56 and on3 76mm turbo with and fmic. Car ran a little rough when I got it(exhaust leaks at collector) and it was only on a street tune to make it run.
So I immediately took the car to LMR not even 4 hours after buying the car.
After all said and done problems ironed out and tune where I should be, it late down 626hp and 800tq @12 psi.
I can't believe how much power these 5.3's will make with minimal effort on a budget build. Ill be putting meth on the car later and ill be praying the 10 bolt holds together!
Old Dec 12, 2012 | 10:15 AM
Rise of the Phoenix's Avatar
Sounds like a bad *** car. How good of a deal did you get on her?
Old Dec 12, 2012 | 10:21 AM
LS1 240sx's Avatar
BANG BANG Awesome
What are your specs, cam? heads? etc... any idea what timing was?
Old Dec 12, 2012 | 10:25 AM
jt76's Avatar
Whats up with the torque?
Old Dec 12, 2012 | 10:28 AM
Y2K_Camaro's Avatar
Veteran: Marine Corps
Stock bottom end?
Old Dec 12, 2012 | 11:18 AM
Stock bottom end with arp rod bolts, ls6 cam, stock 317 heads.
Old Dec 12, 2012 | 12:58 PM
LS1 240sx's Avatar
Stock bottom end with arp rod bolts, ls6 cam, stock 317 heads and ill have less than 8k in the car with the title in hand.
OO man that a copy of my setup, well my cam will be ls6. oooo yeahhhh. congrats with the new purchase.
Old Dec 12, 2012 | 02:46 PM
Blackpanther99's Avatar
Tellez motorsports from the Houston area and the Valley make miracles with 5.3s its amazing what those 5.3s can do!
Old Dec 12, 2012 | 02:57 PM
o2camaross's Avatar
800 tq is sick!! I can believe it, my 5.3 and on3 76mm rocks at 12 psi!!
Old Dec 12, 2012 | 03:45 PM
a-low's Avatar
Some how i dont think thats correct, not to be dick or anything but ive seen this before
and its been dyno related tq spike or whatever you call it.
Old Dec 12, 2012 | 04:06 PM
Y2K_Camaro's Avatar
Thats awesome, I'll be going with either a 4.8 or a 5.3 with the 76mm on3. I was hoping to be in the 600's, this gives me hope lol.
Old Dec 12, 2012 | 04:08 PM
RedRocketZ28's Avatar
You should have no problem doing that with a 6 speed. I put down 606/570 on 14lbs through a unlocked converter and a 4L80E. The on3 is choking my motor something fierce though.
Good numbers op.
Old Dec 12, 2012 | 06:49 PM
I8UR4RD's Avatar
spiked.
Old Dec 12, 2012 | 06:53 PM
Y2K_Camaro's Avatar
Nice, good to know!
Old Dec 12, 2012 | 08:24 PM
o2camaross's Avatar
Yea the torque may be from a spike or something but these on3's are decent units. But anything over 14 psi on a 5.3 and they are done
Old Dec 13, 2012 | 05:33 AM
So 14 psi is all they're good for on a 5.3? What should be the next turbo I go to? And ya I figured the Tq was some kind of fluke, but it will still look badass on a dyno sheet!
Old Dec 13, 2012 | 09:52 AM
o2camaross's Avatar
From my experience 14psi is just about it. That baby 65mm turbine exducer can only flow so much. I went with a knock-off magnum 80mm that has a 77.5mm turbine exducer. I havent put it on yet but It should be all the turbo I need on this 5.3. Alot of guys run the T4 S475 or the PT7675 with great results. Turbonetics also just cam out with there version of the 7675 and a 7875 that should fit exactly like that on3 fits. May want to look into that
Old Dec 13, 2012 | 08:03 PM
Link would be nice! And thanks for the advice, I'm still a total newb with turbos.
Old Dec 13, 2012 | 08:08 PM
Wicked69's Avatar
Really? I am running a 5.3 with 180,000 miles and 25lbs of boost on E85 and meth injection. The 5.3 is completely stock with my XER273 cam, chinese head studs, LS9 gaskets and Patriot Gold springs. I have tuned it myself with HPtuners.
Here is a video from a few days ago. Go to about a minute into it. The boost guage is on the far left.
Here is another video from a few days ago "attempting" to get on the highway. It destroys the 315/60's in all three gears. Stupid nasty on the street!
Old Dec 13, 2012 | 10:29 PM
got-a-ls1's Avatar
you have two, thats a little different as far as backpressure that hes talking about the 5.3 itself can certainly take more then 14psi i ran about 20 on mine and it loved it
